It is currently Jan Sun 23, 2022 7:50 pm
 Post subject: RCA T-100 TV nada high voltage???
PostPosted: Jan Sat 27, 2018 11:00 pm
I recently picked up a rca t-100 B&W tv with the original stand, restoring old radios, I'm getting better but old TV's
I'm just getting started. So I went through and replace all Electrolytics and paper caps. Tubes that were bad were
replaced. Picture tube checks good. When I thought everything was a go, I slowly brought the voltage up, found there is no high voltage.
Pwr transformer seems to be good altho have not been able to locate Sams. Any ideas before finally securing schematic.
 Post subject: Re: RCA T-100 TV nada high voltage???
PostPosted: Jan Sat 27, 2018 11:36 pm
Most often lack of HV is due to an inoperative Horizontal Oscillator. Is the Plate of the 6BG6 glowing red after a minute? (Don't run it like that if it is).
Do you get any sound or at least static in the speaker?
PostPosted: Jan Sun 28, 2018 1:15 am
By golly "You can teach an old dog a new trick" I'll plug in the speaker and see what happens. Stay tuned......
btw the 6BG6 does not get red so good to go on that one
PostPosted: Jan Sun 28, 2018 1:19 am
This doesn't address your HV question directly, but here's a T-100 article with some restoration notes that may be interesting:
https://www.antiqueradio.org/RCAT-100Television.htm
Phil's Old Radios
PostPosted: Jan Mon 29, 2018 8:11 pm
I plugged the speaker in and was hoping for a miracle but it didn't happen. I double checked the 6BG6 tube, it checks good. All filaments are burning but there is no activity including sound. I DL the manual so I guess it's start digging time. If anybody has any ideas(to send me in the right direction) please do, as I said I'm new into tv repair as I would really like to get this going hooked up with a dvd
PostPosted: Jan Mon 29, 2018 8:41 pm
My suggestion is to get the power supply straightened out first. Those chassis mount power resistors really need to be looked at. Several salvage ones l threw away after they were pried open--these were all from sets like yours. I will let others chime in on capacitor upgrades. If you can turn up a test picture tube somewhere, that will save some guesswork later on. Craig
PostPosted: Jan Tue 30, 2018 8:22 am
Greetings to stratozen and the Forum:
In the good old days when I was in TV servicing, an NE-2 neon lamp was very handy. Just bring it near the 6BG6 and it should light strongly if the horizontal sweep circuit is working.
If the horizontal sweep circuit appears to be working, then there is not much else left to go wrong... perhaps the 1B3 or any doorknob capacitors after it or the CRT itself.
If the NE-2 is dimly lit or not at all, check for proper screen voltage on the 6BG6 and make sure the B+ supply is at the correct voltage. Do not attempt to measure the 6BG6 anode (plate cap).
If these voltages are OK, then it is scope time. Look for incorrect or insufficient horizontal drive signal to the 6BG6 grid.
It is possible to have either a bad flyback or a bad yoke. Look for less troublesome things first.
Jim T.
KB6GM
PostPosted: Jan Tue 30, 2018 8:30 am
Hey! Check the B+ first! There's no sound....
Post New Topic Post Reply  [ 8 posts ]  Moderators: Mr. Detrola, 7jp4-guy
Users browsing this forum: compucat, Tom Schulz and 9 guests
