It is currently Nov Tue 30, 2021 12:58 am
 Post subject: Ignition Timing Light Question
PostPosted: Feb Thu 01, 2018 7:15 pm
I picked up an old Sears timing light recently now that I find myself working on more engine ignition systems.
It is the typical gun-like unit that connects to +12 and the vehicle ground.
The pickup wire coming from the gun has a heavy single conductor lead with a Mueller clip on the end. I assume this is not an inductive pickup, and is for connecting directly to the number 1 plug wire.
If my assumptions are correct, this would seem to be an impractical way to connect to an ignition wire on a vehicle with have a boot on the end connectors?
Was there supposed to be an adapter that allowed you to connect the timing light to the ignition wire?
Paul
...... how hard can it be?
 Post subject: Re: Ignition Timing Light Question
PostPosted: Feb Thu 01, 2018 7:32 pm
Looks like this and clips on the spark plug.
PostPosted: Feb Thu 01, 2018 8:27 pm
Yeah, modern engines usually require the inductive pickup. In fact I think that some don't even intend you to connect to the spark voltage. The timing is monitored via the primary (solid state) signal.
Tim
PostPosted: Feb Thu 01, 2018 8:53 pm
Ezactly.
Except mine is missing the springy thingy.
But it should be pretty easy to make something like that. :D
Paul
PostPosted: Feb Thu 01, 2018 10:04 pm
Mine uses an inductive pickup, and it's rather old. Yours must be a lot older.
I never had one of them thar 'springy thingies" ... I want one
PostPosted: Feb Fri 02, 2018 3:14 am
I had one like that at one time.
You stick one end of the spring into the sparkplug connector, the other end of the spring that is larger in diameter, you slip over the plug terminal. Then you just attach the clip to the spring. It doesn't work too well on engines with recessed sparkplugs.
Tim
PostPosted: Feb Fri 02, 2018 3:59 am
That gives me an idea. I may rig up an adapter with a old plug wire so it can reach those recessed plugs.
Paul
PostPosted: Feb Fri 02, 2018 4:42 am
Or you can make a adapter and put it in the distributor which may be easier than a sparkplug.
PostPosted: Feb Fri 02, 2018 5:28 am
Greetings to Paul and the Forum:
I once had an old Sears timing light similar to the one you describe. Mine had a metal case. The insulation on the trigger wire was old and leaky, and the inside of the gun where the capacitance element clipped on the outside of the flash tube wasn't insulated very well either.
After the third or forth time I got bit by the thing, it went into the trash can and I bought a more modern timing light with a plastic case and an inductive pick-up.
My best advice would be to do the same. They don't cost very much money and they are soooo much more user friendly.
Jim T.
KB6GM
PostPosted: Feb Fri 02, 2018 8:13 am
Recap and rewire, just like an old Zenith. :)
I picked up an old RAC engine Tune-up kit with meter, vac/comp gauges and timing light in a pawn shop. You can tell a lot about an older engine with all the tests they illustrate. It only lacks the high-current shunt for checking battery/generator amps.
I guess I got lucky, the springy thingy timing light always worked fine. But had it bit me, I probably would've drove my car over the thing, spring and all, after throwing it as far as I could down the driveway!
-Ed
(And then listen to the air escaping from my tire, punctured by that #^@%@^ spring!)
My life is loosely based on a true story.
PostPosted: Feb Tue 06, 2018 12:39 am
We don't need no stinkin Strobe, we used a light bulb hooked up between the 12volts on the points and ground, when the light went out then the points were connected. we fiddled with moving the distributor till we would get the right reading off of the timing mark on the flywheel. and then a feeler gage just to make sure it worked every time.
Oh and another thing I would always adjust the carburetor for maximum vacuum using the mixture screw, then set the Idle screw to 550-RPM. :mrgreen:
Visit our site:
I was smokinradios Long time ago (2004)
PostPosted: Feb Tue 06, 2018 2:25 am
I used to have one of those timing lights that was simply a neon tube in a plastic case. One wire to ground, the other to the pug. It worked but wasn't exactly bright, in fact you really needed to have the car in a dark place to see marks on the crank pulley. A spot of white paint helped a lot. By the way, ever work on an old Chevy 6? The timing mark was a steel ball pressed into the flywheel and you observed it through a small window that had a pointer.
I still have a "real" timing light that uses a flash tube. It's powered from the ac line.
The last car I had with a distributor was my 84 Olds.
RRM
PostPosted: Feb Tue 06, 2018 8:12 am
When I finally had a timing light it made the process a lot easier, but I still tweaked the timing to suit my ears and feel of the engine vibration, snap in the throttle. The light gave me a better reference point than I could get by bumping the starter. My '67 MGB ran much better a little bit off the "factory" spec. I assumed that was due to valve train wear. I pretty much tuned the valve clearances and carbs the same way, with hands on the running engine.
The best part was the test drive afterwards! I kinda miss those days, but not the crawling around beneath and the vast number of sockets, extensions and wrenches I always ended up dragging out to find the one that fit!
One of the tools in the old tuneup kit that is still useful on modern cars is the vacuum gauge. More dashboards should have one.
-Ed
Users browsing this forum: ttx450cap and 18 guests
