It is currently Aug Thu 22, 2019 4:12 am
 Post subject: HDMI-to-composite converter for home broadcasting?
PostPosted: Feb Fri 02, 2018 11:15 pm
Can anyone recommend a good quality HDMI-to-composite converter? My goal is to play video content (Netflix, etc.) on my iPhone and pipe the output to my Blonder-Tongue agile modulator to broadcast to vintage TVs in my house. I already have an Apple AV adapter that plugs into the phone's Lightning port and gives HDMI output.
Shopping around online, I see quite a few options, ranging in price from under $20 to a few hundred bucks. Has anyone tried one of these?
Thanks!
Phil's Old Radios
 Post subject: Re: HDMI-to-composite converter for home broadcasting?
PostPosted: Feb Sat 03, 2018 2:25 am
I use this HDMI2AV I picked up a couple off eBay for about $6 each. I feed a Roku into it as a source. They both work flawlessly.
"This will be the last radio I bring home. I PROMISE!"
PostPosted: Feb Sat 03, 2018 2:29 am
I've used this one and it works well.
http://www.altronics.com.au/p/a3504a-hd ... converter/
You may be able to find the same model from a local source but Altronics does ship worldwide AFAIK
That looks like the same one, just seen it!
PostPosted: Feb Sat 03, 2018 2:51 am
WOW What a huge difference in price for the exact same unit. :shock:
PostPosted: Feb Sat 03, 2018 5:30 am
Yes I saw that.
However, by the time you take the 20% wholesale discount you get by registering, the exchange rate (AU$1 = US$0.68) and the shipping cost it works out not that much different for us here. Plus we get it the next day.
PostPosted: Feb Sat 03, 2018 10:22 pm
Last year I bought and tested every model I could find on the market today and I was dissatisfied with all of them. The problem is that none properly handled the 16x9 to 4x3 conversion. What I wanted was one that would center-cut the 16x9 image. However, I would have settled for a letter-box conversion (black bars on the top and bottom). None would do this. They all distorted the image by compressing it horizontally to fit.
-Matthew
If it ain't broken, you’re not trying hard enough...
PostPosted: Feb Sat 03, 2018 11:26 pm
Ugh, I hate those compressed pictures.
What about the more expensive models? I haven't looked at details, but perhaps they would offer more control than a basic converter?
Phil's Old Radios
PostPosted: Feb Sun 04, 2018 1:57 am
-Matthew
Using a Roku box as a source, I had no issue with that. I set the output of the Roku to 4X3. It seemed work fine.
PostPosted: Feb Sun 04, 2018 6:42 pm
-Matthew
You could letter-box it yourself by mis-adjusting the height control. :) You could even add a switch and a resistor to make the height change easy!
PostPosted: Feb Sun 04, 2018 10:28 pm
The advantage of Tom's pragmatic suggestion is you don't lose any resolution.....
PostPosted: Feb Mon 05, 2018 3:54 am
-Matthew
If you set the source device to 480P or 480I resolution, you may/should also get an option in that device to choose between 4:3 and 16:9 aspect ratio; choose 4:3 and you should get a proper picture. In DVD players, these is/was also an option to choose between "4:3 letterbox" and "4:3 pan-and-scan"; look for that as well. All of these will be in the source device, none of the converters will have those options.
PostPosted: Feb Tue 06, 2018 1:34 am
What about one of these units ? I bought one off of E-bay for $15 ( looks like it was never used, & comes with a remote) and it has a ton of inputs and different formats. HDMI, USB, component , etc. I hooked it up to my predicta. Check out the video. Much better deal I think. IView- 3500 STB
https://www.youtube.com/watch?v=fhYgD3HOBkI
Tony
PostPosted: Feb Tue 06, 2018 3:33 am
How about this $262.99 unit:
https://www.ebay.com/itm/Smartavi-V2V-HDAVS-HDMI-to-AV-Converter-Downscaler/201405972441?hash=item2ee4bb3fd9:g:pBkAAOSwu4BVyoA5
It better work for that price!
Post New Topic Post Reply  [ 13 posts ]  Moderators: 7jp4-guy, Mr. Detrola
