It is currently Jun Wed 26, 2019 3:00 pm
 Post subject: Hickok 550X - need plan to add 9 pin socket
PostPosted: Feb Mon 05, 2018 6:55 pm
I have a wonderful Military 550X Hickok tester and would like (need) to add a 9 pin socket or adapter to test 12AX7's, etc. I need to see a schematic, or scribble of some kind to wire in the socket or run a plug from an octal socket to an outboard 9 pin socket. Any one done this? and any help really appreciated.
Thanks, Dale
 Post subject: Re: Hickok 550X - need plan to add 9 pin socket
PostPosted: Feb Mon 05, 2018 8:17 pm
These files will get you started.
The tube Data for the I177 and the 550x is the same?.
The MX-949/U is a tube socket adapter for the I177 that should work on the 550X.
Are use it to build a 9 pin socket.
http://radiorestorer.com/hickok510x.PDF
http://bama.edebris.com/manuals/military/i177/
The grid signal of the 550X can kill a 12AX7.
Jimmie
PostPosted: Feb Mon 05, 2018 8:44 pm
Thanks, Jimmie...About $500 is a bit too steep, but with the schematic I might be able to reproduce the adapter or at least most of for my use.
Cheers, Dale
Users browsing this forum: devildog63, Google Adsense [Bot], keith49vj3, MarkD and 16 guests
