Page 1 of 1
[ 10 posts ] |
Author |
mark K
Post subject: Zenith Have no Am/Fm where should I start? Posted: Feb Mon 05, 2018 7:16 pm |
Joined: Apr Tue 07, 2015 2:36 am Posts: 259 Location: Waterford MI
Thanks for looking at my post!
I just recapped this zenith I do have output in the amplifier its working good. But I have 0-Zero Am or Fm reception where would you start schematic Below,
Top |
mark K
Post subject: Re: Zenith Have no Am/Fm where should I start? Posted: Feb Mon 05, 2018 8:59 pm |
doing some voltage testing
Q201 1st am-fm Amp
C=12v B & E = I have NO volts
Where does the voltage come in from here?
Top |
Norm Leal
Post subject: Re: Zenith Have no Am/Fm where should I start? Posted: Feb Mon 05, 2018 9:23 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 37564 Location: Livermore, CA
Hi Mark
Voltages start on page two, toward the right. Squares numbered 1 through 5, marked source. Measure there and work back through resistors and coils.
_________________ Norm
Top |
mark K
Post subject: Re: Zenith Have no Am/Fm where should I start? Posted: Feb Mon 05, 2018 10:16 pm |
Thanks Norm Found it to much solder in the 10mfd cap it connected +/- together.
Top |
egg
Post subject: Re: Zenith Have no Am/Fm where should I start? Posted: Feb Tue 06, 2018 12:00 am |
Member |
Joined: Jan Tue 31, 2012 1:55 am Posts: 10421 Location: Mountains of Mourne. Ireland.
Top |
mark K
Post subject: Re: Zenith Have no Am/Fm where should I start? Posted: Feb Tue 06, 2018 3:24 am |
Thanks for the one page schematic
Top |
fifties
Post subject: Re: Zenith Have no Am/Fm where should I start? Posted: Feb Tue 06, 2018 5:30 am |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 33345 Location: SoCal, 91387
So is it fixed?
_________________ \\\\\\\\\\\\\\\\\\\\\\\\He Who Dies With The Most Radios Wins//////////////////
Top |
mark K
Post subject: Re: Zenith Have no Am/Fm where should I start? Posted: Feb Tue 06, 2018 6:22 pm |
Yes traced it back to a cap I replaced had the solder connecting the +/- together.
Top |
Tom Schulz
Post subject: Re: Zenith Have no Am/Fm where should I start? Posted: Feb Tue 06, 2018 6:53 pm |
Member |
Joined: Mar Sun 01, 2009 10:27 pm Posts: 5052 Location: Ann Arbor, MI
mark K wrote: Yes traced it back to a cap I replaced had the solder connecting the +/- together. You should always not do that as often as you can.
_________________ Tom
Top |
lorenz200w
Post subject: Re: Zenith Have no Am/Fm where should I start? Posted: Feb Wed 07, 2018 10:50 am |
Joined: Jan Mon 16, 2012 4:15 pm Posts: 5931 Location: Near Brandon, Iowa
Tom Schulz wrote: mark K wrote: Yes traced it back to a cap I replaced had the solder connecting the +/- together. You should always not do that as often as you can.  If not even more often!
Top |
