It is currently Oct Thu 17, 2019 6:03 pm
 Post subject: Is this Heathkit isolation transformer OK?
PostPosted: Feb Thu 08, 2018 8:39 pm
As I get into this hobby more and more I think it is time for one of these isolation transformers. What is your opinion on one of this Heathkit IT-1 model? I can pick up this model for about $40. If this one is a bad choice can you please tell me what to look for when choosing one.
Any advice is appreciated,
BB
 Post subject: Re: Is this Heathkit isolation transformer OK?
PostPosted: Feb Thu 08, 2018 8:44 pm
BB
Looks ok. Here is information on IT1:
http://www.w6ze.org/Heathkit/Heathkit_018_IT1.pdf
PostPosted: Feb Thu 08, 2018 8:53 pm
The IT-1 is only rated for 100 Watts.
That wound be good enough for working with AA5 type ratios.
If you plan to work on larger projects you might consider something in the 500 Watt or greater range.
Respectfully Submitted,
Be_Zero_Be
You never used to be older.
PostPosted: Feb Thu 08, 2018 11:25 pm
I have the same isolation transformer.It handled powering my GE 10-tube console no problem.
PostPosted: Feb Fri 09, 2018 4:03 am
I've used mine for many years with out a glitch. Will mention two things the socket on the front won't except a modern polarized plug and is only adjustable down to abt 80v.
As for just using it on AA5 sets most of those are abt 30w. The older ones w/300ma tubes run a bit higher abt 50w. Have used it on my Philco 116X (abt 160w). The output did sag a little but worked ok.
GL
Terry N3GTE
PostPosted: Feb Fri 09, 2018 2:24 pm
I got two of those at hamfests. The first one works great, but the second one turned out to be fried. With an oversized fuse in it. Go figure. I thought of just putting a new isolation transformer in it for a fixed output with fuse protection. As the variable trans is sort of a custom part and there is not room for a variac and a trans. 40 seems high to me but they work fine over their limited adjustment range. Most of the radios I work on are within it's range of output power. But make sure the fuse is correct! I think I pay 10-15$ for mine.
Users browsing this forum: bob91343, Conrad Hoffman, steveg20 and 15 guests
