It is currently Feb Tue 18, 2020 7:23 pm
Post New Topic Post Reply  [ 30 posts ]  Go to page Previous  1, 2
 Post subject: Re: Allied E-10807 filter hum head scratcher
PostPosted: Feb Tue 13, 2018 9:22 pm
check ripple across the filter with an AC meter ? more than 5VAC may be too much
PostPosted: Feb Wed 14, 2018 11:45 pm
Tom - This is an AC/DC set, pulling a tube kills the set.
tubeAMP - good call, there is nearly 11 VAC across the first filter
I really think it's just a poor design. The hum is at the plates of the output tubes which are feed directly from the rectifier with a 33 uF cap. A 47 uf cap makes little difference in the level of hum.
PostPosted: Feb Thu 15, 2018 1:12 am
What sort of rectifier? Tube, metal...... One hates to modify, but it may need to happen, or an alternate DC supply used, is the AC PSU wired correctly?
Marc
PostPosted: Feb Thu 15, 2018 2:21 am
For a 6 volt tube in a series string, you can just put a jumper across the heater if you want to remove the tube.
It is not the ripple at the first filter that I was thinking about. It is the ripple at the second filter cap that would be important here. The choke will provide some filtering even if the cap after the choke is open. But a bad second cap would leave too much ripple for the audio circuits.
PostPosted: Feb Thu 15, 2018 4:11 am
My last post got me to do more thinking. The filter choke could be bad. A shorted turn inside the choke could keep it from acting like a choke. That would cause too much ripple at the second filter cap.
In any case, the ripple at the cap after the choke needs to be almost zero.
PostPosted: Feb Thu 15, 2018 8:40 pm
you may want to try jumping another filter capacitor across the one with 11VAC and notice any changes
PostPosted: Feb Fri 16, 2018 1:31 pm
Thanks for all the suggestions. I tried them all and here's the report:
The ripple at the second filter is only .1 VAC. The cap is new but I also tried a new substitute. The first filter cap is good and I've also swapped it with other new filter caps of various values.
The filter choke measures nearly 400 ohms, the schematic calls for a 200 ohm choke. The choke appears original but could have been replaced. The only extra choke I have is 50 ohms. I tried it and still have the same level of hum.
Taking the 6J5 out of the circuit does not effect the hum, still there. The rectifier is a glass tube.
Maybe I should eliminate the filter choke and use a voltage divider with an extra stage of filtering.
PostPosted: Feb Fri 16, 2018 8:50 pm
I just grabbed a copy of the schematic so that I can see exactly what the circuit looks like.
You could keep the choke and just add a resistor and cap to make a third stage of filtering. But the problem might not be power supply ripple
It looks like the power supply ripple should show up on both output tube grids, in which case it should cancel out. If you can, check for AC on the plate of the 6J5 and see if it is different from that .1 volts AC that you measured on the B+. I am wondering if there could be some coupling from the AC line or some of the filament wiring into the 6J5 plate or the output tube grid. Could the coupling cap be very close to some of the filament wiring? Could there be some solder flux that has become conductive bridging either the plate of the 6J5 or the grid of the output tube to some of the filament wiring?
PostPosted: Feb Sat 17, 2018 4:54 pm
Tom,
You were right in your suspicion that a third filter stage wouldn't help. It makes no difference.
I can't find any evidence of coupling with the AC line or filament leads anywhere in the set or unintended connections between the filaments and grids. The AC at the 6J5 plate is roughly the same as across the 2nd filter. I swapped the 6J5G for a metal 6J5 and that reduced the hum to the point that it is not objectionable when tuned to a station. It's still louder than normal when not tuned to a station but I'm convinced it's working as designed.
I think I am at the end of the road with this radio and thank all of you who helped along the way.
Cheers,
Nick
PostPosted: Feb Sat 17, 2018 6:29 pm
tube shields of course. oscillation, diminished volume. typical
Post New Topic Post Reply  [ 30 posts ]  Moderators: Marcc, Norm Leal Go to page Previous  1, 2
Users browsing this forum: Frank in Selkirk, Google [Bot], rfitts46, rundownrob, thunderbird281 and 23 guests
