It is currently Feb Tue 25, 2020 12:32 pm
 Post subject: ozarka v16 distortion
PostPosted: Feb Fri 16, 2018 11:08 pm
Ok guy's,
I have pulled the v16 out again to look at it and would like to fix issues with distortion.
Gets worse as you increase volume.
Was re-capped and bad tubes replaced.
Replaced an output transformer(used).
All the usual stuff.
Has never had good audio.
16 tubes and 2 speakers should sound way better than this one does.
I know Ozarka was not a great performer anyway, but I am sure that it was meant to sound better than this.
Total and complete distortion which gets much worse when volume is increased.
Different animal here which I know nothing about.
Can't afford to ship it across the country anymore.
Fix it or peddle it?
murf
 Post subject: Re: ozarka v16 distortion
PostPosted: Feb Fri 16, 2018 11:58 pm
murf
Not a piece of crap but a lot of parallel tubes. There are at least 4 tubes you could pull without making much difference.
http://www.nostalgiaair.org/pagesbymode ... 012746.pdf
Distortion is usually caused by biasing of output tubes. Try measuring grid #1 (pin #3) in relation to filament (pin #1) on each 45 tube. Pin #3 must be around 40 volts negative.
PostPosted: Feb Sat 17, 2018 4:50 pm
Hi Norm,
Let me see if I understand what you are suggesting.
Check pin 1 in relation to pin 3?
Or should I check pin 1 to chassis ground and pin 3 to chassis ground?
Murf
PostPosted: Feb Sat 17, 2018 5:47 pm
Measure between pins 1 and 3 not to chassis. Tubes only see voltage at pins. Measuring to chassis from each pin would work but takes two measurements.
PostPosted: Feb Sat 17, 2018 9:54 pm
Ok, Understood.
Thanks for your help Norm.
Will see if I can get up the ambition to tear it out again.
murf
Users browsing this forum: ErikD, Marcc, Yarehobbiesso$ and 4 guests
