It is currently Oct Thu 22, 2020 10:26 am
 Post subject: Avatar Help
PostPosted: Mar Sun 04, 2018 5:53 am
I want to set up an Avatar but I am having no luck. I have resized the picture I want to use and it will not accept it. My resize only has Percentage or pixels. Which should I use? It also asks for a URL but the pictures I want to use is in my pictures file folder and has no url. Can someone help me with this issue???
Linda
Linda
Always looking for GE Bandy Items!
 Post subject: Re: Avatar Help
PostPosted: Mar Sun 04, 2018 6:00 am
Site Admin
http://picresize.com
Nothing to install. You can type in the pixel width or height or both you want and select a maximum file size as well. Resize > download file to your computer > select file ("Upload from your machine") as avatar image.
PostPosted: Mar Sun 04, 2018 6:18 am
If you are using Windows, simply go to Paint, and re-size. At the bottom of the screen it will display the new size. If it isn't small enough, delete and do it again until you get down to 100 pixels per side.
PostPosted: Mar Sun 04, 2018 12:35 pm
Agree...Great program for not only avatars but for posting photos in Forum threads
Step 1 Choose your photo from your computer (they do have 3 practice photos just above Browse if you want to try that first)
Step 2 Resize Your Picture.......Go down to Custom Size click it and then a field entry box appears and then enter 100 Pixels width and 100 Pixels height.
Skip to Step 4... I'm Done Resize My Picture! ...Save your photo.
BTW I had a hard time posting an avatar until someone on here posted that site.. My avatar to the left was done using that site and the dimensions are 100 X 100 pixels.
PostPosted: Mar Tue 06, 2018 6:48 am
I just want to say Thanks to everyone who helped me with my Avatar. It is there now. Not the clearest picture but that is my GE Bandy Doll. Your all very kind and I appreciate it very much!!
Linda
Linda
PostPosted: Mar Fri 09, 2018 3:43 pm
I've never been able to do this because I'm not a computer guru. No problem getting pictures the right size but that's as far as I get. I like this forum but please don't make the assumption that we are all proficient in understanding how everything works. How does the picture get from a saved state to the place where the Avatar (picture) is supposed to reside.
I apologize for my ignorance. It really isn't a major issue but I don't like things I can't figure out.
PostPosted: Mar Fri 09, 2018 4:22 pm
Process your chosen image using http://picresize.com
arf avatar→ Maximum dimensions: Width 100 pixels. Height 100 pixels. File size 6.25KB
Save the processed image to your desktop or an image folder of your choice.
When logged in to arf
go to User Control Panel
click on Edit Profile
this will expand the Options column
click on Edit avatar
now... Browse to the location on your computer where your prepared image is, and upload.
oh... be aware, if your image is rectangular to begin with and you change its width + height to be 100px by 100px (square), it will end up distorted (stretched and/or squashed).
Best to start with a square image in the first place.
PostPosted: Mar Fri 09, 2018 9:57 pm
Site Admin
Just type 100 pixels for the longest side and leave to other dimension blank.
PostPosted: Mar Fri 09, 2018 9:58 pm
To add to what Greg posted, sometimes a 100 x 100 image is still too pixel rich, and exceeds the 6.25 Kb size. In that case, simply use paint to resize it down in steps, until you are below 6.25.
Also, animated avys aren't allowed (I tried once, but was told to change it).
Post New Topic Post Reply  [ 9 posts ]  Moderator: Alan Voorhees
Users browsing this forum: shovelhead13746 and 14 guests
