Author |
Steve Johnson
Post subject: Re: How many tube testers does one need? Posted: Mar Wed 07, 2018 11:14 pm |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 4453 Location: Elbridge NY, USA
Use to have over 300 radios. Got bored. They all did the same thing. Down to about 20 or so now. Then switched to test equipment. Last count I had around 70-80 tube testers. Thinned those out so I'm probably down to 60 or so, at least 40 of them are Supreme. I have two tube testers that I actually use.
_________________ Steve Johnson https://stevenjohnson.com - Steve's Antique Technology
Top |
xwarp
Post subject: Re: How many tube testers does one need? Posted: Mar Thu 08, 2018 2:03 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1063 Location: Tucson AZ
3 so far currently:
Hickok 539B Heathkit TT-1A I-177 made by Munson.
Top |
zarco
Post subject: Re: How many tube testers does one need? Posted: Mar Thu 08, 2018 3:45 pm |
Joined: Jan Mon 28, 2013 9:35 pm Posts: 1633 Location: Santa Rosa, CA
Also had a large and varied collection of tube testers. Got rid of most but kept two TV-7D's and an EICO 667. The latter tests compactrons and later tubes. So far they have tested everything I've needed to except transmitting tubes. Steve
_________________ 'cell phones and the internet are tools, not a lifestyle'
Top |
Dnitram
Post subject: Re: How many tube testers does one need? Posted: Mar Thu 08, 2018 4:51 pm |
Member |
Joined: Sep Wed 04, 2013 2:23 pm Posts: 964 Location: Canton, GA
Somehow worked down to 2 TV-10D/U, a TV-7D/U and a 539C. That's 1 too many for me. The 539C is an amazing calibrated (Paul Hart) example, but though I ALWAYS wanted one, I've used it maybe 4 times in a year. Due to its size, I keep it away from the bench, covered up like a baby. I ought to sell it and BUY something else!
_________________ Real Radios GLOW In The Dark Southeastern Antique Radio Society SARS 1991 www.sarsradio.com K4DLM
Top |
Barry H Bennett
Post subject: Re: How many tube testers does one need? Posted: Mar Thu 08, 2018 6:35 pm |
Member |
Joined: Nov Wed 30, 2016 7:35 pm Posts: 8895 Location: Sunbury, Ohio 43074
Hey Steve ..... got an extra Hickok TV-2 kicking around ???  any condition. Plugging a hole in the collection you know
_________________ Preserving the hist. of electronics, one boat anchor at a time! :) https://www.bbtvtestequipment.com
Top |
Steve Johnson
Post subject: Re: How many tube testers does one need? Posted: Mar Fri 09, 2018 12:11 am |
Member |
Barry H Bennett wrote: Hey Steve ..... got an extra Hickok TV-2 kicking around ???  any condition. Plugging a hole in the collection you know  Nope, no 2s. Got rid of a TV-7 and a TV-4 last year. Just have my 6000A left which I'm using.
Top |
Mikeinkcmo
Post subject: Re: How many tube testers does one need? Posted: Mar Fri 09, 2018 4:55 am |
Member |
Joined: Oct Sun 15, 2006 12:57 pm Posts: 7439 Location: Liberty, Missouri
For the last 50+ years my main tester has been a 533, for tubes post 1960 or so, and the rare compactron I run across, a Heath IT-17 emission tester my Father built in the 70s.
_________________ Pics, Bold & underlined text, are usually links.
Top |
rif1457
Post subject: Re: How many tube testers does one need? Posted: Mar Fri 09, 2018 9:32 pm |
Joined: Jan Mon 29, 2018 4:45 pm Posts: 19 Location: 22664
I'll use either a Sylvania 139, or a B+K 747, depending on the tube being tested. I test CRT's with either a B+K 440, or an Amphenol # 885. The Amphenol also provides a gas test.
Just my two cents.
Pat
Top |
Frank in Selkirk
Post subject: Re: How many tube testers does one need? Posted: Mar Fri 09, 2018 11:19 pm |
Joined: Jan Mon 24, 2011 6:03 pm Posts: 397 Location: Selkirk,MB,Canada
I'm starting to cut back on my collection,I'm 87 and it's time.I have about 50 or 60 pieces of testing equipment,including 12 tube testers.The one I use most is my Eico 666,it will test most of the tubes I run into.I like the short test.
Top |
roguethistle
Post subject: Re: How many tube testers does one need? Posted: Mar Fri 09, 2018 11:46 pm |
Member |
Joined: Aug Mon 08, 2011 4:19 am Posts: 513 Location: Indianapolis, Indiana, USA
I have 4 tube testers. EICO 624 from 1950'S? -recapped and calibrated EMC 211 from 1960's --meter not working very well Precision 912 from 1945- needs recapped and calibrated Jackson 427A from 1930's -needs recapped and calibrated These testers mostly test only tubes from their era. The EICO does not have some of the older tubes on it's chart. That has caused a problem. My EMC had the tube on its chart, but the meter is bad. So, I finally went to the Precision which had the older type tube on it's chart. So it is true that the meters are not all the same. I feel now I have a good array of meters to cover all eras of tubes to be tested. Joe
Top |
Notimetolooz
Post subject: Re: How many tube testers does one need? Posted: Mar Sat 10, 2018 2:23 am |
Joined: May Thu 14, 2015 4:15 pm Posts: 2806 Location: Dallas, TX
I use a B&K 747 and a Heathkit TC-2. I also have a B&K 465 for CRTs.
_________________ Tim It's not the Destination, It's the Journey.
Top |
Jimmie Stewart
Post subject: Re: How many tube testers does one need? Posted: Mar Sat 10, 2018 3:42 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 672 Location: Stafford, Texas USA
Barry H Bennett
I have two TV-2 kicking around, I may give up one. PM me.
I only have 150 tube tester. Need to get down to about 10.
The problem is what to keep.
Jimmie Stewart
Top |
Dnitram
Post subject: Re: How many tube testers does one need? Posted: Mar Sat 10, 2018 6:11 am |
Member |
Ahhh, feeling much better  Sold the 539C that I used maybe 3 or 4 times in the past 6 months so I thought I'd buy something else... So my wife decided we need a new chair!  Happy Wife = Happy Life!  Got 'em down to three above the bench and that's a plenty!
Top |
