It is currently Oct Thu 22, 2020 11:25 am
 Post subject: Adhesive advice for attaching stuff to Bakelite
PostPosted: Mar Tue 13, 2018 4:03 am
Hi Gang,
I'm attempting to reattach a copper loop antenna that runs along the inside of the Bakelite case of a Philco Hippo. The copper is coated with something plastic-y. I know there are a few options, but everything I've tried in the past (superglue, epoxy, silicone) have had various drawbacks. What have you found to be the best adhesive for gluing stuff to Bakelite? Thank you all in advance.
 Post subject: Re: Adhesive advice for attaching stuff to Bakelite
PostPosted: Mar Tue 13, 2018 4:37 am
I used contact cement when I did my Hippo. The antenna is pretty flexible so you can do a section at a time.
Handyman of the apocalypse
PostPosted: Mar Tue 13, 2018 7:10 am
Any type of TACKY glue. A flexible glue.
PostPosted: Mar Wed 14, 2018 6:26 am
Thanks, guys. I got both Elmer's tacky and contact cement today and will try both and compare.
PostPosted: Mar Wed 14, 2018 9:53 pm
I used a hot glue gun on my hippo.
PostPosted: Mar Wed 14, 2018 10:06 pm
You should prepare the Bakelite surface as the Tacky-glue product describes. Maybe even rough up the surface (if inside) so the glue has a better surface to grip.
