It is currently Jun Fri 05, 2020 10:36 pm
 Post subject: Another Variation of the LM386 Based AM Transmitter
PostPosted: May Fri 25, 2018 9:12 pm
In the original 35Z5 circuit, the output of the LM386 audio amplifier is used to modulate the power supply of an RF crystal oscillator. My aim here is to insert a switch-mode modulator between the LM386 and oscillator so that the oscillator operates with a fixed power supply. This also allows the use of a programmable oscillator which does not tolerate a wide power supply voltage variation.
The LM386 output consists of an alternating signal riding on a DC offset equal to half the supply voltage. If this output is chopped by a high-frequency square wave, we get a waveform that resembles an AM signal but not quite. It looks more like a half-wave rectified AM signal where the negative part is suppressed and set to zero.
To recover the negative part of the chopped signal and create our AM signal, we need to recover its envelope by averaging and subtract it from the signal. This operation is equivalent more of less to high-pass filtering with a cutoff frequency set many times higher than the largest audio frequency to avoid distortion.
As shown is the block diagram, the chopper is implemented as two switches driven by an RF square wave. When the square wave is high, the upper switch is on and the lower switch is off, passing the LM386 output to the midpoint of the switches. When the square wave is low, the upper switch is off and the lower switch is on, grounding the midpoint or the chopper output. The average block recovers the audio envelope with an amplitude exactly one half of the actual envelope. The recovered envelope is subtracted from the chopper output to create the AM signal. Since this AM signal is rich in odd harmonics, a high-Q lowpass filter follows with the cutoff frequency matching the square wave frequency. The lowpass filter also serves as an antenna matching network.
In the partial schematic diagram, the chopper switches are implemented as a pair of NPN and PNP transistors (Q1 and Q2). The values of the speed-up capacitors C6 and C7 are chosen to counteract the storage time of the transistors just high enough for the chopped waveform to have 50% duty cycle. C8 is used to reduce the overshoot when Q1 turns off. The audio envelope is recovered by a low pass filter formed by C9 and the primary inductance of T2. This recovered envelope is subtracted from the chopped waveform to create our AM signal across the primary of T2. The output low pass filter and antenna matching network are formed by L2, C17 and C18. Since the bases of the transistors are not ground referenced, a pulse transformer T1 along with C10 are used to couple them to the an RF square wave oscillator. L1, C11 and R5 form an EMI filter and are not required for proper operation. R4 is used for hooking up a voltmeter during tuning. The readout in mV corresponds to the mA current at the LM386 output.
The circuit was prototyped and built with a homemade PCB to fit a BUD plastic box. The telescopic antenna has a fully extended length of 115 cm (45"). The entire unit is mounted on a metal leg of an old torchiere floor lamp which serves as the ground part for the antenna.
Some waveform captures to verify the operation of the unit.
Sine_and_Sawtooth_Modulation_200Hz_50%_50V_per_div_800x370.jpg [ 37.38 KiB | Viewed 1317 times ]
Sine_and_Sawtooth_Modulation_1kHz_50%_50V_per_div_800x370.jpg [ 35.39 KiB | Viewed 1317 times ]
Binh
 Post subject: Re: Another Variation of the LM386 Based AM Transmitter
PostPosted: May Fri 25, 2018 9:16 pm
20kHz_and_40kHz_Sine_Modulation_50V_per_div_800x370.jpg [ 40.81 KiB | Viewed 1316 times ]
Binh
PostPosted: May Sun 27, 2018 8:29 pm
Novel idea well executed. How does it sound?
PostPosted: May Mon 28, 2018 1:29 pm
Macrohenry - Tom - thank you for the kind words. This thing sounds pretty good although it has some distortion issue at very high modulation level.
The idea used behind this implementation may look novel at first but it is really not. This modulator belongs a class of voltage-fed switch-mode converters. Examples of this class are the buck step-down switching voltage regulator and some electronic ballasts for CFL bulbs. The other class is the current-fed converter. Some examples of this second class are the boost switching regulator and the resonant Royer converter. A good place to gain understanding of these two classes is the 1959 conference paper by P.J. Baxandall, "Transistor Sine-Wave LC Oscillators".
There are plenty current-fed modulator implementations based on Sokal class-E tuned single-ended switching power amplifier. I could not find any voltage-fed switching modulator implementation besides the voltage-switching oscillator described in the Baxandall paper. Out of curiosity, I took Baxandall's oscillator and turned it into a voltage-switching modulator to see how well it performs.
Binh
PostPosted: May Mon 28, 2018 4:13 pm
What cores are you using for the coils that you can get such high values with so few turns?
PostPosted: May Mon 28, 2018 6:04 pm
The small ferrite toroid used for the base drive transformer was salvaged from a CFL bulb. It has 10 turns of bifilar wire giving an inductance of 242uH. Its material is probably equivalent to Amidon type F.
The bigger ferrite toroid for the output transformer was used as a bead for a computer power supply. It has 15 turns of bifilar wire giving an inductance of 135uH. Its material is probably equivalent to Amidon type 77.
The 220uH loading inductor (L2) for the antenna was salvaged from a printer switching power supply. When driven by a 2V square wave, it resonates with the antenna capacitance (plus C17 and C18) with a peak amplitude of more than 80V. So its Q factor is at least 40.
Binh
Users browsing this forum: Hue Miller and 14 guests
