It is currently Feb Thu 20, 2020 4:10 pm
 Post subject: At wits end trying to clean clear plastic dial...
PostPosted: Dec Wed 05, 2018 3:40 am
Subject radio is a Westinghouse H-334T7U, and the clear plastic dial is pretty foggy. I've tried different grades of Novus, Plasticx gel, Go-Jo, and even the stuff auto parts stores sell to clean headlights. Nothing seems to work. Am I fighting a losing battle, or possibly my technique isn't quite right?
Thanks!!
Ira
 Post subject: Re: At wits end trying to clean clear plastic dial...
PostPosted: Dec Wed 05, 2018 6:53 pm
If those products didn't work it's probably time to order a new dial from Mark Palmquist:
https://dialcover.com/
There are tutorials on making your own, but Mark makes very nice dials.
John KK4ZLF
PostPosted: Dec Wed 05, 2018 7:25 pm
Thanks, John, but this isn't that type of dial cover; it's hard plastic with the frequencies embossed/molded in. I've got covers from Mark before (he does a great job), but haven't see one like this.
73, Ira KB3I
PostPosted: Dec Wed 05, 2018 7:51 pm
OK.... then try some Mother's Mag and Aluminum polish (auto section). Practice on another piece of plastic and you'll want to follow-up with finer grades of abrasives such as Novus 3, then 2 etc. It will take a lot of elbow grease with each , but hopefully that process will cut through the layer that is discolored (unless it is all the way through).
John KK4ZLF
PostPosted: Dec Fri 07, 2018 7:55 pm
I have had great luck with Mcguires Plastex which you can get at Walmart in the automotive dept... Its made for polishing and taking the fading and yellowing out of automotive headlamps... Works great!
PostPosted: Dec Sun 09, 2018 10:22 pm
Try a dab of Simichrome polish on a microfibre cloth.
Always be yourself. Everybody else is already taken.
