Page 1 of 1
[ 9 posts ] |
Author |
dtvmcdonald
Post subject: Sola transformer hum Posted: Dec Thu 06, 2018 3:32 am |
Joined: Jun Mon 24, 2013 3:00 pm Posts: 1696 Location: Champaign IL 61822
I bought a 500 VA Sola constant voltage transformer off ebay, new surplus. I hooked it up and it works exactly per spec, from 100 to 500 watts (resistive) load. I only had it on about 30 minutes and it did not get warm, but its got lots of mass.
But it hums and buzzes. The sound changes with applied voltage and load. I've used lots of these before, but the largest was 120 VA. There's a modern new one outside my office, a 120VA one, and it hums but not a lot, which is my prior experience.
What's your experience with these?
Is it normal for these big industrial ones to hum?
Top |
Findm-Keepm
Post subject: Re: Sola transformer hum Posted: Dec Thu 06, 2018 3:55 am |
Joined: Sep Tue 30, 2014 6:08 am Posts: 5949 Location: Norfolk, VA
No. I've got the wired-in Sola CV transformer, good for 1800VA, a DoD surplus buy. I have high line voltage... My transformer never hums, but did make some noise when I inadvertently hooked up a 400Hz transformer once.
Some slide into a plastic housing - others have through-bolts holding the EI core together - perhaps something is loose?
Any power-factor correction in the stuff plugged in?
EDIT: One thought - I'm nearly deaf, and wear hearing aids, so I'll have my daughter listen to the Sola to see if I'm just deaf to it's audibles....
_________________ Brian "Capacitor Cosmetologist since 1979" USN Retired 1984-2006 (Avionics/Cal)
Top |
Norm Leal
Post subject: Re: Sola transformer hum Posted: Dec Thu 06, 2018 4:49 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 30748 Location: Livermore, CA
Try tightening bolts holding the core together. Varnish may be needed to stop vibrations which cause hum.
_________________ Norm
Top |
Rich, W3HWJ
Post subject: Re: Sola transformer hum Posted: Dec Thu 06, 2018 5:12 am |
Joined: May Tue 30, 2006 4:46 pm Posts: 10397 Location: Santa Rosa, CA
I assume the resonating capacitor is still good? Rich
Top |
Usually Lurking
Post subject: Re: Sola transformer hum Posted: Dec Thu 06, 2018 6:46 am |
Joined: Jan Tue 16, 2007 7:02 am Posts: 4107 Location: Lexington, KY USA
Those things usually hum. Some of them pretty loudly.
Beware, they also draw power, as well as current, as long as they are humming. So you want to turn it off when not in use.
It is also normal for them to get pretty warm, even without a load.
Ted
Top |
Mr. Detrola
Post subject: Re: Sola transformer hum Posted: Dec Thu 06, 2018 3:04 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 26915 Location: Detroit, MI USA
+1
I have never seen one that didn't hum, and the level of hum does change with the load. The temperature may also surprise you. Often you can hear them from several feet away depending upon the size of the transformer.
_________________ Dennis
Top |
dtvmcdonald
Post subject: Re: Sola transformer hum Posted: Dec Thu 06, 2018 3:10 pm |
I'll try tightening the core. Also, the shell is humming due to magentism. I had that problem in my NC-400 radio as its transformer core was too close to the case. I'll try rubber damping between the case and a steel bar.
As to the caps, they must be OK since it generates a nice sine wave at all loads. The common mode waveform of the output is terrible however ... I need to ground it. A 2.2K resistor works fine.
Top |
Barry H Bennett
Post subject: Re: Sola transformer hum Posted: Dec Fri 07, 2018 1:04 am |
Member |
Joined: Nov Wed 30, 2016 7:35 pm Posts: 8895 Location: Sunbury, Ohio 43074
They do hum ..... some of them loudly. I have one and had to move it to the next room. I read in some of their literature that it’s normal but I cannot recall the exact document
_________________ Preserving the hist. of electronics, one boat anchor at a time! :) https://www.bbtvtestequipment.com
Top |
dtvmcdonald
Post subject: Re: Sola transformer hum Posted: Dec Fri 07, 2018 4:05 pm |
Then all is well. I found the "buzz" due to the magnetic action of the core on the shell, and fixed it with a piece of cardboard jammed between them. Now it just hums.
This ruins my idea, already beautifully enacted, of attaching a power strip directly to the thing to plug radios in. Oh well ... the power strip cost no more, not a penny, than an equivalent extension cord to cut up for the in and out of it. It took 20 MINUTES of my and the Lowe's electical man to find proper fixtures to put on it for the leads! We kept looking for a simple 1/2 inch fitting of the clamp type .. and could not find it! Finally he looked in their supplier's catalog and they make every size except 1/2 inch. I finally found a waterproof fitting that works nicely. At $2.78 a pop.
It will have to be mounted in the utility closet.
And I found why the first time I tried it it did not get hot ... my brain should have realized this. It started out at 25 degrees F. Now it gets barely on the warm-hot border.
Top |
Page 1 of 1
[ 9 posts ] |
Users browsing this forum: wa8dof and 13 guests |
