Is the model number 7-HF-5
?If it is... here is the service information for RCA changer model RP-205
http://www.antiqueradios.com/forums/vie ... 4#p1885374There is a brief section on lubrication.
It would be best to remove and replace all the hardened grease. All the rubber parts may also need replacing due to age related deterioration and correct lubrication applied in the correct place.
For tuners and the likes: When disconnecting interconnecting cables, label them with masking tape
flags or directly with a sharpie.
Example: tuner chassis terminal-A to amp chassis terminal-A
B to B etc.
otherwise you'll get lost when it comes to reassembly
Take your time and work methodically
For anyone disassembling a record changer for the first time, taking photos along the way can often get you out of a jam later on,and, Watch out for the
Dammit clips!Gary Stork at thevoiceofmusic.com is a good guy to deal with (parts and advice).
http://thevoiceofmusic.com/sales_service_lit.htmlHere are a few (
Chris Cuff) video links that will give you an insight into the world of record changers.
viewtopic.php?p=2732362#p2732362 âfollow links.
Welcome aboard SLC
oh... post photos and ask questions...
You can post photos as attachments
straight out of the chute. No need to wait 24Hrs.
Posting photos to a forum thread... The skinny: viewtopic.php?p=2717120#p2717120
