It is currently Dec Wed 08, 2021 10:43 am
 Post subject: Channel Master 6459 Signal Seeker, need hint...
PostPosted: Dec Sun 09, 2018 8:18 pm
Hi all,
Picked up this cool little Channel Master on the bay. It seems to work fine, including the automatic tuning feature.
It has a chunk chipped out of a corner, for which I am planning to attempt a repair. I recently used some JB Weld Plastic Bonder which sets up in a deep black color. So if it is successful, I'll post a pic later, if not, it will never be mentioned again :lol:
Another interesting note. The seller shipped the radio with power on. I set the box on top of our stove which has a RF Noisy processor. The box started hissing and sputtering. :shock: My wife and I looked at each other and had a good laugh.
OK, so here's my question...
Can someone tell me how to remove the back? It seems to require removal of the winding key, which I haven't figured out how to do.
Also, if anyone would have an electronic copy of a service guide for this I'd really appreciate. I've already found a link to a Sanyo schematic which Gregg had posted sometime back.
Thanks, Tim
 Post subject: Re: Channel Master 6459 Signal Seeker, need hint...
PostPosted: Dec Sun 09, 2018 8:29 pm
Same as the Sanyo 10C-320 - Radio Museum may have a manual.
Brian
PostPosted: Dec Sun 09, 2018 10:24 pm
Hey Tim,
Good looking radio & neat story about it coming to life on the stove !
Don't have this model yet, but I've seen both splined and threaded "key's", so best to wait to hear from someone who knows...
Gook luck with the plastic repair---please let us know either way how it turns out.
Looking forward to inside pics and a performance report once completed !
PostPosted: Dec Mon 10, 2018 12:31 am
My guess would be, if the smaller round inside the winding key is a separate item, try holding the key, and turning the smaller round CCW.
PostPosted: Dec Mon 10, 2018 4:19 am
E-mail Vlad, he speaks English.
http://antiqueradios.com/forums/viewtop ... 4&t=296805
Usually they turn anti-clockwise - may be tight. Lol
Best to check first.
PostPosted: Dec Mon 10, 2018 5:21 pm
Thanks all for the suggestions.
The knob rotates counter clockwise pretty easily, feel like reverse direction on a ratchet. Tried pulling, no luck. I don't see any way to disassemble the knob.
I'll be patient as I sure don't want to do any damage.
Sent PM to Vlad, hopefully he'll chime in.
Tim
PostPosted: Dec Mon 10, 2018 5:33 pm
IIRC, that back cover attaching wing screw has a retaining c-clip on the interior - it comes off with the back. Get it loose, and work the back off.
Panasonic, Sanyo, and Hitachi all did the same thing with some radios and those awful 8-track portables.
EDIT:
http://www.tabiwallah.com/radiowallah/sanyo/7sp1d.html
http://www.tabiwallah.com/radiowallah/h ... h667b.html
Pretty common to have the back screws captive..
Brian
PostPosted: Dec Mon 10, 2018 10:19 pm
Got the winding key removed, it mounts on a split splined shaft. I was able to get a dental pick beneath cover to pry the key from the shaft. A few photos below for posterity.
Also, photos of the chip missing from rear cover.
PostPosted: Dec Mon 10, 2018 11:48 pm
Meet "Bondo Ed"...
page-2 viewtopic.php?f=4&t=236680&start=20
A pea size of hardener to a golf-ball size of filler. The stronger you make it, the faster it goes off.
Don't hang around and don't make it too proud as it can be a bugger to sand!
PostPosted: Dec Tue 11, 2018 12:12 am
Thanks Greg, very encouraging.
After what Ed pulled off there, my project should be like falling off a log :lol:
I am noodling out how to make a form to contain the inside section while getting just enough thickness that I won't need to do too much filing, grinding, sanding.
Tim
PostPosted: Dec Tue 11, 2018 12:50 am
De-grease the ragged edge with some alcohol or IPA - use an old toothbrush or small acid brush. Dry soon as some plastics can react/melt.
Cut a Coke can with a pair of scissors, it's ultra thin. Be careful of the razor sharp edges. Place a layer of sacrificial masking tape on its face (longer than required-tails). Bend/shape and wedge/tape in place, taller than required. Apply filler and shape.
Later - pull/peel your shuttering piece away with a pair of pliers. If it remains in place, you can smear the inside faces (overlapping joints) with a small about of Bondo. 3M Micropore Surgical Tape can be used if you are NUTS like me. Lol
:) Greg.
Other solvents...
viewtopic.php?p=2945921#p2945921
Girly nail files are great tools for this.
Use a low tack masking tape. You can make your own by dusting Johnson’s Baby Powder on regular tape.
Edit: You can also cut (Junior hacksaw) corner (shuttering) pieces from an old music cassette box - Super/Krazy glue in place, as long as you can close the case. Do a dry run.
PostPosted: Dec Tue 11, 2018 1:40 am
Looks like some good ideas there Greg.
I like the idea of cutting up a coke can for some formable metal.
Tim
Post New Topic Post Reply  [ 12 posts ]  Moderator: Dave Doughty
