It is currently Feb Thu 20, 2020 2:55 pm
 Post subject: Gluing fabric to wood cabinet
PostPosted: Dec Sun 23, 2018 1:23 pm
Any advice as to which is the best glue to attach book cloth to early wood to cabinets with no bleed through?
 Post subject: Re: Gluing fabric to wood cabinet
PostPosted: Dec Sun 23, 2018 2:10 pm
Local craft store should have Mod Podge or other fabric glue that is suitable.
PostPosted: Dec Sun 23, 2018 10:41 pm
Hi Merrill,
I can't advise on what best glue to use. But to avoid bleed-through I would first seal the wood cabinet with a couple of coats of shellac. Shellac will avoid almost any bleed-through and any type of glue should adhere to it, other than those with a urethane base.
Poston
PostPosted: Dec Mon 24, 2018 12:19 am
The Mod Podge is a sealer and glue in one.
PostPosted: Dec Mon 24, 2018 10:55 am
Site Admin
I like adhesive transfer tape. It's like telephone tape without the cellophane. Just lay in down, peel up the backing, and press the cloth into place. You can do a little repositioning as you work and it's a dry adhesive to begin with, so you don't have to wait for the glue to dry.
PostPosted: Dec Mon 24, 2018 12:19 pm
Thanks all of you.
Merrill
cron
