Author |
Old Rad Lab
Post subject: Avatar picture (I give up).... Posted: Jan Thu 10, 2019 4:54 am |
Member |
Joined: Feb Sat 10, 2018 4:58 pm Posts: 757 Location: Livermore, CA
OK, folks, I have been trying off and on for a year now to add an picture to my profile, but with no success. I am starting with a high resolution picture of my dog (very endearing, I must tell you), and by the time I get it to the required pixel resolution and overall 6 kilobyte or so picture size, it no longer even looks like a dog. What could I be doing wrong? I have read all the instructions on adjusting pixel size and resolution and such using online tools, but again, when I finally get it to conform to ARF requirements, it looks like %$#*&... It looks good down to about 10 kbytes, but once you go below that, the picture just pixelates and falls apart. Perhaps I am starting with too high an initial resolution (the original file was probably 15 Mbytes or so)?
I've tried about a dozen times with no success. An ideas? Could I PM the picture to someone and they would send me back a file that would work (bless their souls, payment not included, of course)?
Any ideas would be appreciated before I pull out what remaining hair I have left...
-Bryan
Top |
Macrohenry
Post subject: Re: Avatar picture (I give up).... Posted: Jan Thu 10, 2019 5:16 am |
Member |
Top |
Old Rad Lab
Post subject: Re: Avatar picture (I give up).... Posted: Jan Thu 10, 2019 5:26 am |
Member |
Macro, I'm starting with a jpeg picture like this: Attachment:
Right now this is 20 kb on my end, but when I go below that, the picture just falls apart. By the time I get to 6 kb or so to meet ARF requirements, it's nothing but jumbled pixels... EDIT: For picture shrinking, I'm using both online tools and the native software on my Mac (Preview or Adobe). -Bryan
Top |
wiscojim
Post subject: Re: Avatar picture (I give up).... Posted: Jan Thu 10, 2019 5:35 am |
Joined: Sep Fri 07, 2007 2:27 am Posts: 6227 Location: Grand Chute, Wisconsin
I just put your image in MS Paint and set the reduction to produce a 100 by 100 pixel image to give me this 12.0KB image: Attachment:
Is that small enough to be used as an avatar here? Or maybe this one (3.80KB)? Attachment:
Top |
Macrohenry
Post subject: Re: Avatar picture (I give up).... Posted: Jan Thu 10, 2019 5:39 am |
Member |
wiscojim wrote: I just put your image in MS Paint and set the reduction to produce a 100 by 100 pixel image to give me this 12.0KB image: Attachment: The attachment doggie.jpg is no longer available Is that small enough to be used as an avatar here? . Pixel count is fine, but it needs to be less than 6.25K. I got the same thing in my version of MS Paint, 12 KB, and I see no way to compress it using MS Paint. Old Rad Lab, I just compressed it in Paintshop Pro 5.0 and this copy is only 3.29 KB. Just save this photo and you should be good to go.
Attachments: |
Top |
wiscojim
Post subject: Re: Avatar picture (I give up).... Posted: Jan Thu 10, 2019 5:47 am |
Macrohenry wrote: wiscojim wrote: I just put your image in MS Paint and set the reduction to produce a 100 by 100 pixel image to give me this 12.0KB image: Attachment: doggie.jpg Is that small enough to be used as an avatar here? . Pixel count is fine, but it needs to be less than 6.25K. I got the same thing in my version of MS Paint, 12 KB, and I see no way to compress it. I just added another smaller one to my post above. I used the previous one, opened it in MSPhotoEditor and saved it as a .jpg at a quality factor of 83. .
Top |
Old Rad Lab
Post subject: Re: Avatar picture (I give up).... Posted: Jan Thu 10, 2019 6:20 am |
Member |
Macrohenry and Wisconsin Jim, you are The Man! Or in this case, The Men! As you can see, the immortal Spencer The Wonder Dog lives on through my avatar. Good dog, that Spencer, but 14 years was a lot for a 100 lb Chocolate Lab, so he's gone to the great boneyard in the sky... Plenty of tube radios up there, I'm pretty sure. And bones.
Thanks! Bryan
Top |
Ed in SoDak
Post subject: Re: Avatar picture (I give up).... Posted: Jan Thu 10, 2019 6:23 am |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 6559 Location: Black Hills, SD 57745
My trusty Photoshop 2.5 ca. 1993 would always report an 8kb file size no matter the compression level, so I think that may be caused in part by the minimum sector size of my hard drive. Even my own avatar at 66x80 (5.28k pixels) reports as taking 8kb disk space.
Jpeg compression relies on similar colors or patterns, there's not all that much redundant data in your dog's pic that meets that criteria. Just doing the math of 100x100 nets a 10k pixel count. A 79x79 image would be 6241.
I thought it would be a cake walk, but it took going to a smaller pixel dimension for Photoshop to nudge file size down, near as I can determine due to the HD sector size issue. -Ed
Attachments: |
_________________ My life is loosely based on a true story.
Top |
Old Rad Lab
Post subject: Re: Avatar picture (I give up).... Posted: Jan Thu 10, 2019 6:40 am |
Member |
Thanks, Ed, and my first confession is that such issues are now beyond me. Years ago I did write code in assembly language, and also submitted my Fortran punch cards to the scary-looking guy behind the glass window, but I have to admit that those techniques no longer applied to getting my &^$*# avatar picture size under 6.28 kb...
-Bryan
Top |
19&41
Post subject: Re: Avatar picture (I give up).... Posted: Jan Thu 10, 2019 7:59 pm |
Member |
Joined: Apr Thu 21, 2011 2:00 am Posts: 4319 Location: Georgia, 30236
Looks like Mr. Dog has his high beams on.
_________________ "Any sufficiently advanced technology is indistinguishable from magic." — Arthur C. Clarke
Top |
Old Rad Lab
Post subject: Re: Avatar picture (I give up).... Posted: Jan Thu 10, 2019 8:20 pm |
Member |
19&41 wrote: Looks like Mr. Dog has his high beams on. All the better to peer into dark spaces of old radios...! -Bryan
Top |
azenithnut
Post subject: Re: Avatar picture (I give up).... Posted: Jan Thu 10, 2019 8:23 pm |
Member |
Joined: Jan Mon 18, 2010 2:13 am Posts: 19462 Location: Dayton Ohio
Ed in SoDak wrote: My trusty Photoshop 2.5 ca. Wow, you still use this version? I started with Photoshop 3.0 back in 1996 running on Windows 3.1. I worked up to version 5.5 before switching over to GIMP. I still have 5.5 on an old G3 iMac i use on rare occasion  -Steve
_________________ Radio Interests -Zenith -Sparton -Pre-War FM Consoles and floor models, the bigger, the better!
Top |
egg
Post subject: Re: Avatar picture (I give up).... Posted: Jan Thu 10, 2019 8:37 pm |
Member |
Joined: Jan Tue 31, 2012 1:55 am Posts: 10366 Location: Mountains of Mourne. Ireland.
Late starters... Lol  Greg.
Top |
Don Cavey
Post subject: Re: Avatar picture (I give up).... Posted: Jan Fri 11, 2019 3:20 pm |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 14903 Location: Fernandina Beach, FL
egg wrote: Late starters... Lol  Greg. Cool. I have PS 7 and can use about 5-10% of it efficiently. But I do like it.
_________________ Don
Top |
azenithnut
Post subject: Re: Avatar picture (I give up).... Posted: Jan Fri 11, 2019 5:12 pm |
Member |
You would say that i'm a late starter. I did not own a computer or even use one regularly until February 1996.
Top |
Art Hoch
Post subject: Re: Avatar picture (I give up).... Posted: Jan Fri 11, 2019 6:58 pm |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 3892 Location: Kansas
I'll make my umpteenth plug for Thumbsplus 7 for picture editing. It' s free and easy to use.
Top |
WB7ANG
Post subject: Re: Avatar picture (I give up).... Posted: Jan Sat 12, 2019 7:36 am |
Member |
Joined: Feb Thu 04, 2016 2:41 am Posts: 361 Location: South Greeley.
azenithnut wrote: You would say that i'm a late starter. I did not own a computer or even use one regularly until February 1996.
-Steve I didn't own or use one until 2009!
_________________ Sometimes the best part of this hobby is that i have a rock station at both ends of the band....
Top |
radios2100
Post subject: Re: Avatar picture (I give up).... Posted: Jan Sat 12, 2019 8:51 am |
Member |
Joined: Oct Sat 18, 2014 8:16 pm Posts: 1501 Location: Galena, Ohio
WB7ANG wrote: azenithnut wrote: You would say that i'm a late starter. I did not own a computer or even use one regularly until February 1996.
-Steve I didn't own or use one until 2009! What's a computer??
Top |
pixellany
Post subject: Re: Avatar picture (I give up).... Posted: Jan Sat 12, 2019 1:03 pm |
Member |
Joined: Jul Mon 26, 2010 8:30 pm Posts: 26885 Location: Annapolis, MD
To know all about computers, all you need is one teenaged son. In my child-raising years almost 50 years ago, there was muttering about getting a computer before the Apple-II appeared. We finally got a Franklin Ace (Apple-II clone) in 1980. Within days, my son had it playing music by writing assembly code. (The only hardware feature for this was a command that "clicked" the speaker.) He wound up being a system engineer all through the early MacIntosh evolution.
_________________ -Mark "Measure voltage, but THINK current." --anon.
Top |
glue_ru
Post subject: Re: Avatar picture (I give up).... Posted: Jan Sat 12, 2019 1:16 pm |
Member |
Joined: Dec Tue 01, 2015 5:31 am Posts: 2354 Location: Columbus Ohio
Spencer was a fine looking friend, sorry for your loss of him.
_________________ Joe - There's no shortage of cruelty to animals: http://joinASPCA.org
Top |
Who is online |
Users browsing this forum: rsingl and 11 guests |
