It is currently Dec Mon 09, 2019 8:41 am
 Post subject: Rippled- dried out cathedral cabinet?
PostPosted: Feb Sat 23, 2019 6:08 pm
Have a cathedral radio that otherwise is in nice shape. The problem is it seems to have ripples in the cabinet going across the curved top. Not the veneer - but all the way through so the top has a subtle "scallop" effect to it if you run your hand across the top. I think it has to do wit moving it into a dry environment. Anyone try spraying a little water inside the curved cabinet top to eliminate this effect? The finish on the outside seems to be fine.
 Post subject: Re: Rippled- dried out cathedral cabinet?
PostPosted: Feb Sat 23, 2019 6:55 pm
Don't think that would work even if you had a press, to fix you will have to do some reshaping on outer skin with a polyester filler and then re veneer entire top and all along the sides and down to base molding. That's the way I would do it, done it before on un even top and rippled surfaces.
PostPosted: Feb Sun 24, 2019 10:42 pm
What Fred said.
Is it an AK? 206?
"I just might turn into smoke, but I feel fine"
http://russoldradios.com/
PostPosted: Feb Sun 24, 2019 10:51 pm
Just send it to Fred... :wink:
