It is currently Jul Tue 23, 2019 10:36 am
 Post subject: Fairbanks Morse 8A What kind of wood/ veneer is this?
PostPosted: Feb Mon 25, 2019 8:49 pm
Hi Guys,
Veneer on top is ruined and needs to be replaced, what type of wood is this?
I was thinking of replacing the top with the same type as the sides.
Thank you for your help !!
Lewis
 Post subject: Re: Fairbanks Morse 8A What kind of wood/ veneer is this?
PostPosted: Feb Tue 26, 2019 12:24 am
Walnut?
PostPosted: Feb Tue 26, 2019 3:52 am
The sides look like walnut so chances are the top is walnut, too. Have fun and make it work.
PostPosted: Feb Tue 26, 2019 4:17 am
Your radio is... Fairbanks Morse model 8AC-2 with chassis 8A
https://www.radiomuseum.org/r/fairbanks_8a_1.html#c
image: viewtopic.php?p=2852720#p2852720
image: viewtopic.php?p=2710060#p2710060
fyi... Refinishing Fairbanks-Morse 8AC-2
viewtopic.php?f=7&t=328122
American walnut (crown cut).
:) Greg.
PostPosted: Feb Tue 26, 2019 5:16 am
most definitely walnut.
PostPosted: Mar Fri 01, 2019 7:04 am
Thanks guys!!!
Bought walnut veneer for the top, waiting for it to arrive.
Thank you Greg for the previous post, looks like they wanted to use Van Dyke Brown, I just tested Perfect Brown and it matches "perfectly" with the trim. Van Dyke is way too dark.
I have the chassis restored and working, I will post photos on the electrical forum when I get a chance.
For now the cabinet is stripped, I used Citrus Strip from home depot, works great ! followed by a few wipe downs using lacquer thinner.
I will use Mohawk Ultra Clear Gloss for the the cabinet with Perfect Brown for the trim.
Will post photos when done.
Lewis
