Page 1 of 1
[ 15 posts ] |
Author |
Raleighcopter
Post subject: My Silvertone 4586a project Posted: Apr Wed 03, 2019 10:36 pm |
Joined: Apr Wed 03, 2019 6:41 pm Posts: 100 Location: Raleigh, NC
I picked up a 1936 Silvertone 4586a for 100 bucks. The cabinet needs refinishing but the veneers are in great shape. There's a bit of veneer repair needed near the base but it appears minor. The bezel and glass appears original with only a small crach in the bezel that I'll repair. I pulled the chassis and it needs recapping so I'll do that and align it afterwards. The dial pointer is off, pointing to 1700 when the cap is at full mesh so I'll need to figure that out. The speaker is in great condition with no tears in the cone I'll also replace the grille cloth with something appropriate.
The dial also requires cleaning and I'm not sure how to clean it or what to use.
I've recapped radios but never refinished a cabinet. Any thoughts?
Top |
Rich berg
Post subject: Re: My Silvertone 4586a project Posted: Apr Thu 04, 2019 12:48 pm |
Hi Dave, be very careful, on some radios the dial was painted with a water based paint like my Coronado, any water even a spray with window cleaner will ruin it.
Top |
Raleighcopter
Post subject: Re: My Silvertone 4586a project Posted: Apr Thu 04, 2019 1:21 pm |
that's why i'm asking. i figure anything that breaks like the dial will be difficult to impossible to replace without buying another 4586.
Top |
Raleighcopter
Post subject: Re: My Silvertone 4586a project Posted: Apr Thu 04, 2019 1:24 pm |
i'm trying to post photos but i'm not sure how to get them to show up...
Top |
pixellany
Post subject: Re: My Silvertone 4586a project Posted: Apr Thu 04, 2019 1:29 pm |
Member |
Joined: Jul Mon 26, 2010 8:30 pm Posts: 26899 Location: Annapolis, MD
Raleighcopter wrote: i'm trying to post photos but i'm not sure how to get them to show up... Resize for a maximum of 800 pixels on the longest side (600 is usually adequate), then save in JPEG format. The dialog for uploading is at the bottom of the composition window. All details here: https://antiqueradios.com/forums/viewto ... 2&t=167677
_________________ -Mark "Measure voltage, but THINK current." --anon.
Top |
Raleighcopter
Post subject: Re: My Silvertone 4586a project Posted: Apr Thu 04, 2019 2:26 pm |
Top |
chaz
Post subject: Re: My Silvertone 4586a project Posted: Apr Thu 04, 2019 4:02 pm |
Joined: Nov Mon 05, 2007 11:08 pm Posts: 2907 Location: Calgary Alberta
Top |
Raleighcopter
Post subject: Re: My Silvertone 4586a project Posted: Apr Thu 04, 2019 4:27 pm |
My concern is that area on the left front corner about 1/3 up from the bottom. That area of about 1" x 5" is basically bare wood. I'm not sure how to repair that area.
Top |
Raleighcopter
Post subject: Re: My Silvertone 4586a project Posted: Apr Sun 07, 2019 3:55 am |
It didn't clean up well as I suspected so I stripped it and am preparing to refinish it. It'll get sealer, a couple coats of shellac and then a bunch of lacquer. It's a good looking cabinet without the finish.
Attachments: |
Top |
Rich berg
Post subject: Re: My Silvertone 4586a project Posted: Apr Sat 13, 2019 2:02 pm |
Hi Dave, what a beautiful cabinet! you are doing a great job. cant wait to see it done. Rich
Top |
Raleighcopter
Post subject: Re: My Silvertone 4586a project Posted: Apr Sat 13, 2019 3:09 pm |
It's getting there. It's got 2 coats of shellac as a primer, 3 coats of grain filler, 2 more coats of shellac and 2 coats of toned lacquer. I mixed 1.5 ounces lacquer, 1 ounce thinner, and 12 drops of transtint dark walnut and shot 2 coats on the grille, base, and shoulders using a paasche H airbrush with 35 psi air. Next is some red mahogany tint in clear lacquer over the entire cabinet to darken it up a bit. I'm new to toning lacquer and very unsure of myself when it comes to mixing colors. Wish me luck.
Attachments: |
Top |
Raleighcopter
Post subject: Re: My Silvertone 4586a project Posted: Apr Sat 13, 2019 4:27 pm |
...and here it is with one coat of tinted lacquer (10 drops dark walnut, 7 drops red mahogany, 4 oz lacquer, 2 oz thinner). I'll do 2 more coats with the same toner and then start laying on clear lacquer. Still shooting at 35 psi.
Attachments: |
Top |
Raleighcopter
Post subject: Re: My Silvertone 4586a project Posted: Apr Sat 13, 2019 6:54 pm |
I wound up putting 4 coats on the entire cabinet. All that's left is a dozen or so clear coats, then I'm off to work on the chassis while it hardens for a week
Attachments: |
Top |
Raleighcopter
Post subject: Re: My Silvertone 4586a project Posted: Apr Sun 14, 2019 2:05 am |
I'm out of lacquer so I must be done. There's 8 coats of clear on it over the 6 coats of toned lacquer. I'll let it sit for a week or two and then I'll rub out the finish.
Attachments: |
Top |
Raleighcopter
Post subject: Re: My Silvertone 4586a project Posted: Apr Sun 14, 2019 2:06 am |
Top |
Page 1 of 1
[ 15 posts ] |
Moderator: Peter |
Who is online |
Users browsing this forum: No registered users and 2 guests |
