It is currently Jan Sun 23, 2022 12:54 am
 Post subject: Knob from 1941 Fada table top radio.
PostPosted: May Tue 07, 2019 2:19 am
Fada knob with set screw in wrong place.
Bill J.
 Post subject: Re: Knob from 1941 Fada table top radio.
PostPosted: May Thu 09, 2019 5:11 pm
Don't think that knob is from FADA.
Bruce Hagen
PostPosted: May Fri 10, 2019 1:59 am
You could be right Bruce, I don't really know. They were on the Fada, a Model 148 by the schematic. It had no back and a crack on top. I had to redo some previous work which included replacing the dogbones. Kinda tight chassis underneath. At least troublesome for my hands and fingers.
Bill J.
PostPosted: May Fri 10, 2019 1:08 pm
Maybe I'm wrong, but isn't that knob supposed to have a metal "spring" insert near the top of that hole so it could just be pressed onto a typical quarter inch "D" shaft? Maybe someone lost the spring and in an effort to keep the knob in use just drilled and tapped a hole and put in the insert that it currently has? Even if the other one is the same, don't discount the idea because I would have done that just for the sake of keeping it all alike.
Yea, I know, I'll slink back under my rock... :P
Tony
PostPosted: May Sat 11, 2019 8:24 am
Those don't seem to be the correct knobs in the first place;
https://www.google.com/search?q=Fada,+M ... 52#imgrc=_
PostPosted: May Mon 20, 2019 5:07 pm
anbitet66 is spot on --some folks aren't too particular when it comes to setscrew placement after the fact --I see this quite a bit.
The knobs themselves seem to be a little oversized for that radio. The photo Fifties has posted look to be the correct knobs for this set.
There are smaller bullets available.
Users browsing this forum: highstream and 6 guests
