It is currently Jan Sat 16, 2021 12:35 am
 Post subject: g.e. mystery radio.
PostPosted: May Sat 11, 2019 1:15 am
i just found this radio looking for something else in my junk stash.
this radio was at my grandmother's house and i know it was in service until mid 80's.
when i was a kid i saw it working.
Years later i found it and took it home to repair it. i remember it powered up, but it had no sound. also the cone the speaker was broken
time has passed and never reapired it.
in 2010 i had it on a shelf and it fell because of a big eartquake.with this fall the ballast tube broke ( the metal one on the right) it looks complete but is broken.
I have all the knobs for this radio. the cabinet is in good shape, but the finish is ugly. also the back is missing. Also is missing one tube ( maybe i pulled it to repair another radio, but i don't remember.
Anyone knows what model it is? tube lineup is typical for an AA5
anyone knows where i can ge a schematic?
also, the ballast tube will be a problem
also i will needsome grill cloth
 Post subject: Re: g.e. mystery radio.
PostPosted: May Sat 11, 2019 2:05 am
http://www.nostalgiaair.org/pagesbymodel/138/M0008138.pdf
Alignment instructions and parts list here: https://www.radiomuseum.org/r/general_el_je530.html
What input voltage will you be using?
Jay
PostPosted: May Sat 11, 2019 3:36 am
thanks,
i will be using 220V
looking at the specs mine is j-530
PostPosted: Apr Thu 09, 2020 2:01 am
i am waiting some parts to start with this one.
the ballast will be complicated.
the speaker cone os broken also
PostPosted: Apr Thu 09, 2020 4:36 am
Looks like you need a ballast that will drop about 100 volts at 0.15 amps.
Here's an example:
https://vacuumtubesinc.com/index.php/115-98.html
Any 5" speaker can be installed. Ideally it would be 3.5 ohms impedance, but an 8 ohm speaker will work very well.
Burl Ives, RIP, oldtimer.
[:l>)
PostPosted: Apr Sat 11, 2020 3:11 am
0,15 amps is only for the heaters, actually is 0,2 amps.
i was thinking about dropping voltage with capacitors. i will need 2 caps, one to drop 100v @ .15 amps 50hz and another to drop arond 69V @ 0,05amps
50Hz
i need 4,7uf and 2.2 uf. i am thinking using a class y safety capacitor.
Never tried this, but it should work
Post New Topic Post Reply  [ 6 posts ]  Moderators: Norm Leal, Marcc
Users browsing this forum: CharlesD, IlikeTech, kirk57, lorenz200w and 27 guests
