Page 1 of 1
[ 8 posts ] |
Author |
brnhornet52
Post subject: source for 1920's speaker wire Posted: Apr Fri 19, 2019 1:43 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 385 Location: Bristol TN 37620
Does anyone have a source for the 1920's tinsel wiring? Don't think AES has it anymore.
Top |
Post subject: Re: source for 1920's speaker wire Posted: Apr Fri 19, 2019 2:27 pm |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 14407 Location: S. Dartmouth MA 02748-1225 USA
_________________ Smith's Ale Gives Strength, Smith Bros. Brewers, New Bedford MA
Top |
thunderbird281
Post subject: Re: source for 1920's speaker wire Posted: Apr Fri 19, 2019 4:08 pm |
Member |
Joined: Feb Sat 06, 2016 1:47 am Posts: 2975 Location: La Mesa Califonia
Top |
JnTX
Post subject: Re: source for 1920's speaker wire Posted: Apr Fri 19, 2019 5:51 pm |
Joined: Nov Tue 14, 2017 5:09 am Posts: 2027 Location: Austin, Texas
For the places where you don't care as much about original appearance, vacuum cleaner power cord makes good speaker wire. The ribbed insulation doesn't look as out of place as the modern slick stuff, it is highly flexible, and is a good fit in most plugs. You only have to find one junk cleaner sitting on the curb to get a lifetime supply.
Jay
Top |
brnhornet52
Post subject: Re: source for 1920's speaker wire Posted: Apr Sat 20, 2019 2:33 pm |
Thanks Guys,
Will check the sources out
Top |
Brasspounder
Post subject: Re: source for 1920's speaker wire Posted: Apr Mon 22, 2019 5:41 pm |
A Google search revealed sever vendors. Go beyond he first page and find listings for both spools and by the foot. Described as for "speaker repair" so might be the right stuff. Dave
Top |
brnhornet52
Post subject: Re: source for 1920's speaker wire Posted: May Wed 15, 2019 2:47 pm |
Hi Guys,
Just wanted to follow up a little. Have a Freed Eisemann FE50 speaker with a good Western Electric driver that needed rewired. The speaker has an odd configuration in that it requires lugs, rather than phone tips or spade connectors on the driver side.
Now, the primary sources never responded at all. (Jackpine and oldradiosareus.) I contacted phonecoinc.com (being the driver is Western Electric) and they responded immediately. They were able to provide a cord with no problem at all, and were very interested in helping the radio community in addition to their phone business. They were friendly, very responsive, and interested in how they could help in the problem.
I'd definitely give them a call should you need the cloth covered speaker wire, as its pretty much the same as antique phone wire of the period.
Top |
jim rozen
Post subject: Re: source for 1920's speaker wire Posted: May Wed 15, 2019 9:01 pm |
Joined: Mar Wed 16, 2011 10:44 pm Posts: 1061 Location: Peekskill, NY
Phoneco will also provide the correct lugs to terminate cloth-covered tinsel wire.
Another trick I learned recently is to easily terminate that wire with phone tips, I crimp on a lug, cut the end of the lug off so the crimp section is still present, fill the phone tip with solder, flux the crimp, and then bury that in the solder.
Top |
Page 1 of 1
[ 8 posts ] |
Who is online |
Users browsing this forum: No registered users and 2 guests |
