It is currently Jan Mon 17, 2022 10:30 am
 Post subject: Need a Selector switch or compatible for a Knight RF650
PostPosted: Jun Wed 05, 2019 5:50 am
Hello
I got a Knight KG650 in a lot of test equipment . its missing a few knobs and for some reason the selector switch.
I was wonder can i just get another 5 position selector switch ( ie ebay) or does it have to be the selector switch that came with the unit ( part # 432206)
just starting out in this and going to be asking a lot of questions
 Post subject: Re: Need a Selector switch or compatible for a Knight RF650
PostPosted: Jun Wed 05, 2019 12:38 pm
The selector switch is probably custom for the instrument. The schematic will tell you the layout of each switch section. I cannot check it here...
Might be able to adapt some other but would need a bit of design work if it’s a soecial
PostPosted: Jun Wed 05, 2019 12:55 pm
The switch is two section, 5 pole with a special wiper. You'd be better served buying another, whole instrument....
There are some on eBay:
https://www.ebay.com/sch/i.html?_odkw=k ... 0&_sacat=0
no affiliation....
Brian
PostPosted: Jun Wed 05, 2019 12:59 pm
Looks like you could adapt a 4 deck 7 position switch cut I tend to agree with the “find another one” philosophy
PostPosted: Jun Wed 05, 2019 1:42 pm
I have a parts unit, it's the earlier version with the dark grey panel but the switch ought to be the same. Looking at it, you'd need to have an exact replacement for the original part due to the unique design of the contacts and the shorting segments.
PostPosted: Jun Wed 05, 2019 3:00 pm
Why seven position?
It's only 5 - it switches the ranges.
All other terminals are common or wipers. Terminal 7 and it's wiper short out unused coils, leaving only the selected range active.
Brian
PostPosted: Jun Wed 05, 2019 3:08 pm
one little mistake ................ Of course, the other issue is if the replacement switch indexing matches the instrument panel markings.
Best to just get a donor unit
PostPosted: Jun Thu 06, 2019 2:51 am
Thanks for the information. I had a feeling it would be a unique part . i guess I will use it for a donor chassis and hopefully get lucky and get another one.
PostPosted: Jun Fri 07, 2019 7:12 pm
You can get creative and design something to do the same job. You use one section to select the coil in use, and another to select the other coil. If you don't short to ground the unused coils it will still work. So a two pole 5 position can be used. Those are readily available. Just make sure the knob will fit and the detents are spaced the correct angle to match panel marking.
Search on ebay.
Users browsing this forum: Pierrot du 82 and 9 guests
