It is currently Oct Thu 22, 2020 2:38 am
Post New Topic Post Reply  [ 586 posts ]  Go to page Previous  1 ... 21, 22, 23, 24, 25, 26, 27 ... 30  Next
PostPosted: Apr Tue 23, 2019 8:43 pm
Hi Tom,
Its really hard to say what it might go for since its an auction. Yes- this is the more economical model and so its likely going to be for less than the 12 tube variations. We will be taking photos of it this Saturday and adding it to the auction catalog.
PostPosted: May Wed 01, 2019 4:50 pm
Here's some more recent restorations.
1: This 1960 Telefunken " Rythemus". Late model tube table set using PCB boards.
This radio had EVERYTHING wrong with it. Initial power up had one of the power resistors smoking and the Selenium rectifier getting hot. So that meant it would need replacement, which I did with a new silicone diode bridge unit. Interestingly enough for whatever reason the chassis was split into two with the tuner unit and power supply mounted on their own individual chassis.
Upon testing again with rebuilt power supply the resistor still smoked and I could see that neither of the output tubes were getting filament. Testing both showed one of the tubes was shorted HARD. After replacing that the set came to life but it was clear that tapping the chassis would cause a serious short for the 6 volt filament section. The PCB board was riddled with dry solder joints and cracks. After spending an hour re-soldering most of the PCB this solved the shorting issue.
As with other nice sets, it too got a bluetooth unit installed feeding into the tape input.
The brass was really corroded. So it was masked off an polished.
2: This really ugly Motorola. But hey- it sounds great!
3: Zenith "Pancake". This was donated a year ago, was nasty and filthy looking with a crack in the right rear of the case. I guess I felt sorry for it. Recapped, re-aligned, and probably a few hours worth of polishing to bring back the bakelite. Knobs were soaked in solution of hot water and amonia to remove stains. Nice and sensitive set. Lots of rotten rubber wiring had to be replaced as a quite a bit of it was carrying significant current.
PostPosted: May Wed 01, 2019 7:00 pm
Bob,
Thanks for explaining about the output tube short being an issue that would cause this radio to go dead. I'm assuming that this radio had no fuse? Did the output tube short also cause the selenium rectifier to go bad as well or did the bad selenium rectifier cause the output tube to go bad? Or, are they not related to each other?
Thanks a lot, Tom
PostPosted: May Wed 01, 2019 7:32 pm
The set actually had 3 fuses. One for the 120AC, one for the 6 volt winding of the transformer, the other I assume for the other winding. When tested nothing came on and so I jumpered the open fuse. It had done its job. Either way some sort of catastrophic event had happened.
PostPosted: May Wed 01, 2019 8:33 pm
Thanks for the information, Bob.
PostPosted: May Thu 02, 2019 12:24 am
I love this thread. I'm hooked! I wish I got more involved when my aunt was getting rid of her collection.
PostPosted: May Mon 06, 2019 4:55 am
Bob, just spent last Sunday night going through all 24 pages of this thread and was amazed at the number of sets you have restored to functionality. I envy you the ability you have to be able to bring some of these basket case sets back from the brink. If I lived where you do I'd consider it a privilege to offer my time to the museum in helping restore these sets. Keep up the good work and keep us posted here on the forum!
"If at first you don't succeed, keep on succin' til you do succeed" - Curly
Dan
PostPosted: May Mon 20, 2019 4:09 pm
Its been awhile since I posted stuff here. The honest truth is that we are ramping up for this year's Radio Day- our museum's big event in July- which means some 200 sets need to be either cleaned up, restored and otherwise made presentable. A lot of recent donations have come in. As poor of an excuse as this is I've simply forgotten to take pictures of some of the projects. But here are a few recent jobs.
No.1: A very large, 40 pound German set. Its a Nordemende "Tannhauser" which I think means something like " Big sounding house" or something along those lines. This was a recent donation that had sat in storage for 10 years. It was filthy.
If I had to pick a brand that is my least favorite to work on it has to be this brand. For whatever reason Nordmende thought it was a great idea to mount components onto PCB boards, attach the boards to the chassis, and then wire them in. So that means that in many instances there is no way to remove the boards to get to the undersides without de-soldering the tons and tons of delicate wires from them. Its a really stupid design. The only way to deal with this is by snipping the old components off and leaving enough of the old leads in which to solder the new stuff to.
The whole thing is built in layers and some parts can only be gotten at via using long hemostats or tools along those lines.
This has many issues: Bad electrolytics, a short in the pilot lamp wiring, shorts in and around the EBF-89 tube, filthy contacts as a result of storage and two bad tubes. At one point FM was not working at all. While I had tested the ECC85 tube that tends to get "poisoned" in these German sets that same tube wound up failing between testing it, overhauling the set and testing again. I assumed there was a short in there somewhere and after hours of poking and prodding I handed it to another shop tech, who promptly tested the ECC85 and found it to be bad.... Annoying.
But it now works. It is a elaborate set with actual, true FM stereo, 6 speakers and numerous tone options.
Sorry, I forgot to take pics of the innards, but this 1946 era Philco. It has its original finish, brought out and made shiny once more with 4-5 applications of car wax:
A Zenith "Consoltone" racetrack. Corrosion on the front trim means its not auction-worthy and is deemed for one of our traveling antique shows instead.
This Heathkit mono amp with push-pull 6L6 ouputs.
A very clean GE with its original, pristine finish.
This Admiral clock radio with a design so ugly its cool.
And this Hamilton Beach mixer for me. Always wanted one of these things.
PostPosted: May Mon 20, 2019 5:55 pm
i hope you also have the stainless cup with mating bracket for the mixer?
PostPosted: May Mon 20, 2019 7:54 pm
Bob,
You're so patient to get that Nordmende working again. I'm impressed it has six speakers. It must sound wonderful.
That's a nice looking blender. You should be able to make some great milkshakes with it.
PostPosted: May Wed 22, 2019 5:06 pm
Last night's project:
<a href="https://imgur.com/VwNJpdq"><img src="https://i.imgur.com/VwNJpdqh.jpg" title="source: imgur.com" /></a>
Not sure you guys have seen these but they are pretty goofy. You press a button on the top and the front doors and an antenna panel pops open. That also trips a switch to turn the set on.
This was sitting for a few weeks in the garage. I've done one of these before and they are a royal pain. Getting at the bottom of the capacitor can means unsoldering a plate from below. There's little room to install the new ones.
Initially the set did not work. I would get a hum but nothing else. Most of the tubes tested very weak. Long story short, for whatever reason I didn't test the last tube. It was bad and I found that out after poking and prodding in the set for an hour.
The case was polished with Novus No.2, which does a great job on plastics.
PostPosted: May Thu 23, 2019 10:47 am
Bob - Just a comment on Nordmende Tannhauser. Following are the names of Nordmende radios that were inspired by operas: Tannhauser, Parsifal by Wagner (also Cosima, his famous 2nd wife and perennial inspiration); Carmen by Bizet; Elektra, Arabella by Strauss; Traviata, Rigoletto, Othello, Falstaff by Verdi; Fidelio, Coriolan (unfinished but with frequently played overture) by Beethoven; Turandot, Boheme by Puccini; Norma by Bellini; Roland by Lully; Stradella by Flotow. One radio is also named after Caruso, an Italian tenor from the early 20th century.
Jiri
PostPosted: Jun Tue 04, 2019 10:31 pm
Heeeres the latest...
1: This very art deco looking "continental" set. It was donated last week. We are keeping it as a museum item. I don't have time to restore museum stuff as we're gearing up for the radio day even in July, so instead all efforts will be focused on actual auction or future antique show sets. So all I did was give this a cosmetic clean up job.
2: I forgot to take before and chassis pics of this. Oh well. Its a pretty large Zenith and AM/FM. After a recap it works pretty well. Its very similar as far as the circuit design to their more common larger hi-fi sets with the big speakers.
3: A Crosley. This was a basket case. When I first tried it out it sounded really weird, like the speaker was somehow in the back of the cabinet. When I opened the back a speaker just fell out. Someone had jerry rigged a crappy little speaker in there and the original was gone.
Plus of course lots of wiring was rotten.
The paint was pretty much ruined and there was also a crack in the case. So it was taken apart, sanded down and painted.
The brass bits were soaked in CLR and then polished.
And I snapped my favorite nippers. Crap!
And here it is all done
4: This grubby GE clock radio. These are such a pain in the ass to take apart and re-assemble. But anyway, the plain white case meant there would be no way it would ever sell.
Testing revealed the IF/RF cans were suffering silver mica disease so off to the museum for replacements...
Replacing the cans solved the issue. After a recap I cleaned the case, took it outside and prepared for paint.
The dial front was snapped out and the two halves painted. Cocktail pink is very popular with the ladies...
And here it is with new paint.
PostPosted: Jun Mon 10, 2019 4:53 pm
Here's Sunday's project.
You won't find many of these in the US as they were sold for the Japanese domestic market. Its a 50's era JVC ( Victor Company of Japan), which was originally a part of RCA, which severed ties with JVC at the onset of WW2. Its a small "consolette", made for the small apartments common in Japan. Luckily it actually had two voltage settings. When I started working on it the setting was at 100 volts, which is the voltage used in Japan. I was able to move the fuse to a 115 setting meaning at least the tubes aren't going to cook alive.
Its interesting to me that while the set is a Japanese market unit that the parts, stampings on the chassis and tubes are all in English.
On the back was what appeared to be an electrical outlet. This was for additional accessories such as a record or tape player, and I assume these drew very little current. Why? Well take a look at the pathetically thin wire connecting it!
As I cannot assume whoever buys this won't do something dumb, like plug in a hair dryer or something to that outlet I removed the wiring to it.
The chassis was overall in nice clean condition. All caps were replaced. I kept a few of the old ones as they say " Victor" on them, which is kind of unique.
Bluetooth was added and goes into the auxiliary input. Interesting that there were three inputs: One for tape, record player and radio and yet they all fed into the same thing meaning the user would have to turn one device off over another. Oh well. It works.
This thing sounds surprisingly good for what it is and looks like. Its got decent bass and clean highs.
PostPosted: Jun Wed 12, 2019 4:20 pm
Here's another set from the last few days.
Before I continue, do people actually read this anymore or is it getting redundant?
Anyway... this was donated about a month ago:
Its a 40's era Canadian RCA. I really liked the dial glass "slats" running across the front. But as seen the set was in very poor cosmetic condition and I am certainly no expert at refinishing.
As with a number of American brand, Canadian made radios it seems pretty robust and "beefy" compared to the equivelant US-made set. Clearly even in the 40's Canada must have still have a varied electrical grid as seen by the huge transformer meant to handle from 20-60 Hertz.
Someone had been in there before. I forgot to take a chassis before pic but basically the previous guy had tacked on an additional electrolytic to the original, leaving the original in circuit. Very clumsy and of course the set didn't work. I cleaned all that up and got it back to playing great.
The dial slats are made out of plexiglass and were scratched and abraded. Going over them with Novus No.2 brought back the shine.
As for the case, the top had to be sanded down and refinished. The rest, in order to blend with the new finish was cleaned, rubbed down with steel wool and given one light coating of varnish. Also- the dull brass plate was stripped and polished as well.
PostPosted: Jun Wed 12, 2019 4:32 pm
I truly enjoy your posts, thanks.
Rickey N4IDQ "Turn your radio on!"
PostPosted: Jun Wed 12, 2019 5:22 pm
I'm reading them and enjoying them!
Maybe not the most talkative in the thread, but I'm here :D
PostPosted: Jun Wed 12, 2019 5:46 pm
I enjoy immensely your detailed posts on radio restorations. Please keep it up!
PostPosted: Jun Wed 12, 2019 6:01 pm
Not redundant at all. I always read any updates you posted.
PostPosted: Jun Wed 12, 2019 7:25 pm
Hey Bob!
I'm a big fan of your posts! When I see one of your posts, I click onto it right away. I really like seeing all the different radios with all kinds of problems and the solutions you use to clean them up and bring them back to life. Please keep up the good work!
Post New Topic Post Reply  [ 586 posts ]  Moderator: sofaslug Go to page Previous  1 ... 21, 22, 23, 24, 25, 26, 27 ... 30  Next
Users browsing this forum: jmsent, pbc64, rfeenstra, westcoastjohn and 33 guests
