Author |
tbone8
Post subject: LED power light causing 2mHz interference? Posted: Jul Fri 05, 2019 4:12 am |
Member |
Joined: Dec Wed 23, 2015 3:03 am Posts: 1282 Location: Northwest Indiana 46350
Built this little amp using an LM4871. I added a power indicator light (at the top of the schematic) and it has given me all kinds of grief  . First, my dumb a$$ wired it in series with the 5V power and got a horrendous buzz on the output  . Figgered that out and rewired it to as the schematic shows. That little bugger now drowns out any signal input with a nasty 1.97mHz wave. Cut the lead to and and it works fine. Can a guy use a blocking cap to filter that out? Hope everyone has a happy and safe 4th! Attachment:
_________________ "It's amazing what you can accomplish when you throw safety out the window", Brent Butt
Top |
Rich, W3HWJ
Post subject: Re: LED power light causing 2mHz interference? Posted: Jul Fri 05, 2019 6:46 pm |
Joined: May Tue 30, 2006 4:46 pm Posts: 10408 Location: Santa Rosa, CA
What are the specs for LA1? Voltage & current.
Wiring it as you have, the circuit sees 5V minus the LED voltage. It the LED is white, that leaves you less than 2V to run the rest of the circuit. U1 may be oscillating?
Top |
tbone8
Post subject: Re: LED power light causing 2mHz interference? Posted: Jul Fri 05, 2019 8:17 pm |
Member |
Rich, W3HWJ wrote: What are the specs for LA1? Voltage & current.
Rich Here is the LM4871 spec pdf: http://www.ti.com/lit/gpn/LM4871. The LED is a 1.8V yellow I believe. I am a little confused as to how that LED takes away voltage to the IC?
Top |
n3uvt
Post subject: Re: LED power light causing 2mHz interference? Posted: Jul Fri 05, 2019 8:51 pm |
Joined: Sep Tue 15, 2015 1:16 am Posts: 886 Location: 18424 PA
You need decoupling caps of 0.1uf and/or .01uf on that power rail somewhere.
Top |
Rich, W3HWJ
Post subject: Re: LED power light causing 2mHz interference? Posted: Jul Sat 06, 2019 1:57 am |
If the supply voltage is 5 V DC and the LED drops 1.8V, there is only 3.2 V left to run the IC.
Why not just connect the LED from 5V+ to ground using about 100 ohm resistor to limit the current?
Rich PS: Yes de-coupling caps would be good.
Top |
tbone8
Post subject: Re: LED power light causing 2mHz interference? Posted: Jul Sat 06, 2019 2:21 am |
Member |
Rich, W3HWJ wrote: If the supply voltage is 5 V DC and the LED drops 1.8V, there is only 3.2 V left to run the IC.
Rich PS: Yes de-coupling caps would be good. I must be missing something, wouldn't be the first time  . 5V comes in, one branch goes to the 220 ohm dropping resistor then the LED. Another branch goes to pin 7 of the IC. I am lost on how that LED steals 2 volts from the IC? Attachment:
Top |
Jim Mueller
Post subject: Re: LED power light causing 2mHz interference? Posted: Jul Sat 06, 2019 3:18 am |
Member |
Joined: Sep Mon 16, 2013 2:42 am Posts: 4454 Location: Tucson, Arizona U.S.A.
Quote: First, my dumb a$$ wired it in series with the 5V power and got a horrendous buzz on the output If you posted the original circuit, that's how it drops the voltage.
_________________ Jim Mueller
Top |
tbone8
Post subject: Re: LED power light causing 2mHz interference? Posted: Jul Sat 06, 2019 3:30 am |
Member |
Jim Mueller wrote: Quote: First, my dumb a$$ wired it in series with the 5V power and got a horrendous buzz on the output If you posted the original circuit, that's how it drops the voltage. Yes, I originally put the LED in series with the 5V. I figgered out my error and it is wired like the schematic I posted, now. Still get the 2 mHz signal coming out the amp. Removed the LED, amp works like a champ. Don't need the LED, try trying to learn why it still screwed up my circuit and how to remedy it.
Top |
Jim Mueller
Post subject: Re: LED power light causing 2mHz interference? Posted: Jul Sat 06, 2019 6:37 am |
Member |
First add a 0.1 uF supply bypass capacitor, preferably ceramic, to U1. Make the connections as short and direct as possible. Then, are all the other components around U1 connected with short, direct leads? If not, make it so. Is it laid out so that no output comes near any input, either for one stage or for the whole device? If not, rearrange it. Is whatever you are using for a load match what U1 wants to see? If not, fix it.
Top |
radiotechnician
Post subject: Re: LED power light causing 2mHz interference? Posted: Jul Sat 06, 2019 11:00 am |
Joined: Sep Thu 23, 2010 6:37 am Posts: 12437 Location: Powell River BC Canada
Please show the rest of the circuit. Where does the +5 volt arrow go.
Top |
Norm Johnson
Post subject: Re: LED power light causing 2mHz interference? Posted: Jul Sat 06, 2019 3:53 pm |
Member |
Joined: Sep Wed 10, 2014 2:01 am Posts: 2285 Location: Costa Mesa, California
LEDs are very complex devices and come in many forms. I have had similar problems with interference when using cheap LEDs. The bulbs made for direct replacement for 6.3 ac bayonet type fixtures do not produce radio interference as far as I have experienced. White LEDs can be the most complex devices. The white light can be produced using a number of ways, including the blending of red, yellow, and blue. I would suggest you try using a red LED instead of white and see if that produces radio waves.
_________________ KK6IYM
Top |
Rich, W3HWJ
Post subject: Re: LED power light causing 2mHz interference? Posted: Jul Sat 06, 2019 5:23 pm |
Individual LEDs do not oscillate or produce radio waves. They are just diodes with a higher Vf. Not rectifiers, as the reverse voltage is very low, so don't use them on AC.
LED replacements for AC incandescents can have various circuit elements built-in, like a rectifier or bridge. LEDs designed for use on 120 VAC have a high frequency driver circuit which can cause all sorts of RFI.
I believe your oscillation is occurring in the amplifier circuit, either from low Vcc or lack of de-coupling and bypassing.
Top |
Rich, W3HWJ
Post subject: Re: LED power light causing 2mHz interference? Posted: Jul Sat 06, 2019 5:31 pm |
Quote: White LEDs can be the most complex devices. The white light can be produced using a number of ways, including the blending of red, yellow, and blue. I would suggest you try using a red LED instead of white and see if that produces radio waves. I know of two ways to produce white light from an LED. Most common is to use a blue/UV LED and coat it with a phosphor. The UV excites the phosphor, just like in a fluorescent tube, emitting a white light with a good bit of blue color, depending on the phosphor. Unlike a fluorescent, there is no ionized gas in an LED to cause the noise typical of fluorescents (and mercury vapor tubes). The other way is to combine 3 LED chips(red, green, blue) in a single package and balance the RGB colors to give white. That's the hard way to do it. https://www.ledsmagazine.com/smart-ligh ... s-magazineRich PS: there may be a third way to get white light. Drive a huge current through a blue LED and as the internal wire bonds vaporize, you may get nearly white light for few milliseconds
Top |
tbone8
Post subject: Re: LED power light causing 2mHz interference? Posted: Jul Sat 06, 2019 6:13 pm |
Member |
Norm Johnson wrote: LEDs are very complex devices and come in many forms. I have had similar problems with interference when using cheap LEDs. The bulbs made for direct replacement for 6.3 ac bayonet type fixtures do not produce radio interference as far as I have experienced. White LEDs can be the most complex devices. The white light can be produced using a number of ways, including the blending of red, yellow, and blue. I would suggest you try using a red LED instead of white and see if that produces radio waves.
Norm Winner, winner, chicken dinner! The LED I used was from a box of parts I picked up a while back. Oddly enough, they were labeled "free" in the ziplock baggie. Free musta meant cheap crap led, who knew that bugger could cause such a mess... Which leads to a question, how does a guy know when buying LED if its a "quality" LED???
Top |
Norm Johnson
Post subject: Re: LED power light causing 2mHz interference? Posted: Jul Sat 06, 2019 8:21 pm |
Member |
https://en.m.wikipedia.org/wiki/Light-emitting_diodeThe Wikipedia discussion implies that LED technology has been changing rapidly and there is no way to know if a cheap LED is just old technology or the result of inexpensive new improved production methods. I wonder if you put a RF choke (1mH) between the device and the rest of the circuit if that would help. There may be some switching action in the device that produces the RF. Norm
Top |
Rich, W3HWJ
Post subject: Re: LED power light causing 2mHz interference? Posted: Jul Sat 06, 2019 8:50 pm |
Quote: There may be some switching action in the device that produces the RF. Whatever floats your boat! Rich
Top |
Elvirafan
Post subject: Re: LED power light causing 2mHz interference? Posted: Jul Sat 06, 2019 11:08 pm |
Member |
Joined: Feb Sun 05, 2012 5:12 pm Posts: 1047 Location: North Syracuse NY 13212
I once built a 2 stage transformer coupled AF amp. Whatever I played through it came out on the TV screen as interference bars (this was in the analog days around 1967). As best I could figure, one of the junctions was oscillating in the VHF range. Even some of the Edison incandescent bulbs could oscillate!
Bob
_________________ Life is too short to be serious all the time.
Top |
Jim Mueller
Post subject: Re: LED power light causing 2mHz interference? Posted: Jul Sun 07, 2019 6:07 am |
Member |
The transistors you are using, both separate and in the IC, are capable of operation in the hundreds of megahertz. Therefore, the circuit must be wired as if it were for 200 MHz even though the desired signal is audio. Proper bypassing, short leads, inputs separated from outputs, etc. are a must. Otherwise, it is likely to produce its own signal at whatever frequency things happen to resonate at.
Top |
radiotechnician
Post subject: Re: LED power light causing 2mHz interference? Posted: Jul Sun 07, 2019 8:49 am |
In other words snivets.
Top |
wazz
Post subject: Re: LED power light causing 2mHz interference? Posted: Jul Tue 09, 2019 2:32 am |
Member |
Joined: Jun Wed 08, 2011 2:33 am Posts: 11349 Location: Ohio 45177
Try a cap across the LED and see what that does. If it is making noise, that will bypass it to ground. Something like .01-.1uF.
_________________ Reddy Kilowatt says; You smell smoke? Sorry about that!
Top |
Users browsing this forum: No registered users and 11 guests |
