It is currently Oct Thu 22, 2020 2:35 am
Post New Topic Post Reply  [ 141 posts ]  Go to page 1, 2, 3, 4, 5 ... 8  Next
 Post subject: Instruction manual for an Eico 470 oscilloscope?
PostPosted: Aug Wed 07, 2019 3:34 am
Note: NOT the more common 460. I got the construction manual (was also available as a kit), but I'd really like to have the instruction manual if anyone has it. I need to align mine after recapping it.
 Post subject: Re: Instruction manual for an Eico 470 oscilloscope?
PostPosted: Aug Wed 07, 2019 4:29 pm
If you don't find one, here is a guy who says that he has them, I think $17. No affiliation...
http://www.tinywebshop.com/Manuals/man_eico.html
PostPosted: Aug Wed 07, 2019 8:30 pm
The vendor doesn't define which manual he's selling (operating or assembly - the 470 had two separate manuals).
PostPosted: Aug Wed 07, 2019 8:42 pm
That site is where I got my assembly manual.
PostPosted: Aug Thu 08, 2019 12:32 am
http://bama.edebris.com/manuals/eico/470/
PostPosted: Aug Thu 08, 2019 1:16 am
That's the construction manual, not the instruction manual.
PostPosted: Aug Thu 08, 2019 4:39 am
I looked at the schematic and the only "alignment" I see is setting the input compensation. In general this is a matter of tweaking the trimmers until a square wave is displayed as square as possible. The procedure for the 460 will give you an idea of this.
RRM
PostPosted: Aug Thu 08, 2019 5:10 am
Funnily enough, I'm reading the 460 book right now...
There's 3 adjustments inside. 2 are trimmer caps for adjusting the 10 and 100 attenuator settings, C102 and C103. The other internal adjustment is called a very helpful "CAL. ADJ." in the construction book. It's R108 on the schematic. I have no idea what it adjusts.
The 460 has a few more adjustment screws inside, so it's not directly similar.
PostPosted: Aug Thu 08, 2019 5:32 am
R108 adjusts the voltage on the internal calibrator. When you select the internal calibrator, is there some kind of note that indicates what voltage is used?
PostPosted: Aug Thu 08, 2019 6:17 am
The circuits are not identical because they are different models but the principle is the same and it's not complicated.
RRM
PostPosted: Aug Thu 08, 2019 11:12 am
Eico 460s ran hot and needed attention to keep the DC amplifiers happy.
And charred resistors were known to unsolder themselves from the
printed circuits.
On the bright side it had a fine trace with a lighted graticule.
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Aug Thu 08, 2019 4:51 pm
printed circuits.
Huh? I built my 460 about 1967, it's still in use, has none of those problems, and doesn't use printed circuits. It's all hand wired on a metal chassis.
RRM
PostPosted: Aug Thu 08, 2019 5:38 pm
I have about four 460s, and I built at least one in the past. And I remember
parts on a board close to the CRT socket getting very hot and loose.
Also I remember a 300 ohm twin lead from the front preamp section
to the board at the back.
I will go to the pile and have a look as it has been about forty years
since touching one.
(there is mention of a late version of the 460 using a solid state power
power supply and no 6AX5) -- just a mention..
If I have one of these, I'll take a photo.
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Aug Fri 09, 2019 2:03 am
Well that's good to hear that it isn't complicated. The problem is that I'm a newbie and have never aligned an oscilloscope before. I can fix anything... IF I got the correct manual. Any pointers would be greatly appreciated!
Nope! The construction manual says follow the tests in the Operation section of the instruction book.
PostPosted: Aug Fri 09, 2019 2:15 am
Well it doesn't much matter what voltage you use as a calibrator, as long as you know how much it is. I suggest running the control over its range to see what you get, and then returning it to its former setting. Once you establish what it can do, the proper figure will be obvious. Usually one Volt or 5 Volts, etc. Then you can watch it and adjust gain to get the required number of divisions.
PostPosted: Aug Fri 09, 2019 2:19 am
Greetings to ZombieElvis and the Forum:
You have two threads on this instrument. If you go back to the other thread:
viewtopic.php?f=6&t=362339&hilit=+Eico
...in the last post, I told you exactly what R108 was for and how to set it.
Please do take care to read what people write here, otherwise it becomes a waste of everyone's time.
Jim T.
KB6GM
PostPosted: Aug Fri 09, 2019 3:09 am
R108 adjusts the calibrate voltage, which apparently comes from the 6.3 Volt transformer winding. Since that starts out at about 20V p-p, I assume the pot sets the voltage somewhere around 1 Volt p-p or maybe 5 v p-p. It's not stabilized so it's only approximate. (The diagram shows no resistance values.)
A better way might be to clip the sine (before R108) with a pair of zener diodes and calibrate to that. Then you have a voltage that doesn't vary with the power line. But these kits were very price sensitive and a pair of diodes would have had too much cost impact.
There are many ways to improve this oscilloscope but most who own it probably want to keep it original. If you want better performance there is no shortage of inexpensive options.
PostPosted: Aug Fri 09, 2019 3:55 am
since touching one.
There's a metal sub-chassis near the CRT socket with a twin lead to the front end.
RRM
PostPosted: Aug Fri 09, 2019 5:48 am
Greetings to Bob91343 and the Forum:
The schematic with the parts list on the side (for values) was posted by the OP at the following URL:
https://imgur.com/p0IwJ7a
Based on this drawing (with parts list) I built a quick and dirty LTSpice simulation of the calibrate circuit. The voltage that can be obtained at the calibrate switch contact (junction of R106 and R107) ranges from 250 mV peak-to-peak to 600 mV peak-to-peak. Therefore, I recommended that a 500 mV external, accurate 60 Hz signal be introduced into the scope at the front panel input terminals and that this signal be set for 10 divisions of peak-to-peak amplitude. Without changing the scope gain controls, the scope should be switched to the calibrate mode and R108 adjusted for 10 divisions peak-to-peak. This will calibrate the scope at 60 Hz. How well the calibration will hold at higher frequencies is anybody's guess, but this should be pretty good for a service grade scope.
If you want the LTSpice file, you will have to PM me; .asc extensions are not allowed by the ARF software.
Jim T.
KB6GM
PostPosted: Aug Fri 09, 2019 8:46 pm
Jthorusen, you sure did. I'm sorry. I never got past the graticule part of that post. I looked up on Google maps where the nearest office supply store was and the 2 closest to me have closed since I was there last, then I got distracted trying to fix my signal generator. You know how I said I can fix anything if I got the manual? That's a slight lie. I'm not even sure if the panel meter works right. First I had a sticky needle, then once I got that cleaned out, I still can't figure out why I couldn't calibrate the RF output right.
You mentioned a transparent sheet. Has anyone made a replacement graticule before? I've been searching around online for transparency films for overhead projectors. I can whip up an evenly spaced grid in Excel. My tube is a big'gun at 7", but an 8.5" sheet should cover that just fine. Would something like this work? https://www.amazon.com/dp/B07KS3VTQQ/re ... tDb6PD53FF
I decided to check R108. Apparently they used every single drop of flux they had on it. It's now glued shut and its resistance values are jumping all over my VTVM and DMM. Ehh, never mind. I was able to work it out smooth though I never did get it open.
Users browsing this forum: Google [Bot], keith49vj3, SX-42 and 21 guests
