Author |
spsquires
Post subject: Westinghouse model 801 grandfather clock radio. Posted: Aug Wed 28, 2019 3:11 pm |
Joined: Mar Fri 07, 2014 10:20 am Posts: 4027 Location: A0E 1K0 NL Canada
I have what I believe to be a Westinghouse model 801 columinair 8 grandfather clock radio and is looking for a good set of schematics.
Top |
pixellany
Post subject: Re: Westinghouse model 801 grandfather clock radio. Posted: Aug Wed 28, 2019 3:27 pm |
Member |
Joined: Jul Mon 26, 2010 8:30 pm Posts: 29177 Location: Annapolis, MD
Radiomuseum has the schematic
_________________ -Mark "Voltage is fun to watch, but it's the CURRENT that does the work."
Top |
spsquires
Post subject: Re: Westinghouse model 801 grandfather clock radio. Posted: Aug Wed 28, 2019 4:11 pm |
I got that printed. Also found some info on pacific tv for just model 801 but the 801 looks to have more caps . Also here is chassis picture
Attachments: |
Top |
pauls.ironhorse
Post subject: Re: Westinghouse model 801 grandfather clock radio. Posted: Aug Wed 28, 2019 4:40 pm |
Member |
Joined: Aug Tue 28, 2018 9:22 pm Posts: 2825 Location: Sanford Fla 32771 (USA)
Interresting the threaded shield cans. I found one on a home built equipment in some junk that I acquired. Wonder whats inside yours, mine had coils.
Attachments: |
_________________ Paul of Florida ….I had my patience tested. I’m negative. https://paulsironhorse.smugmug.com/
Top |
spsquires
Post subject: Re: Westinghouse model 801 grandfather clock radio. Posted: Aug Wed 28, 2019 5:04 pm |
Mine is the two if transformers which will have coils.
Top |
spsquires
Post subject: Re: Westinghouse model 801 grandfather clock radio. Posted: Aug Wed 28, 2019 6:02 pm |
Top |
Tarpawns
Post subject: Re: Westinghouse model 801 grandfather clock radio. Posted: Aug Wed 28, 2019 8:14 pm |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1366 Location: Cape Breton Island Canada
What's the number on that capacitor pak (Polymet?) underneath that yellow capacitor on the left hand side on your set .....C4621?....And how many pins or terminals of it?....The other one is a C4517 or 4517 nearby?
Ken
Top |
spsquires
Post subject: Re: Westinghouse model 801 grandfather clock radio. Posted: Aug Wed 28, 2019 9:08 pm |
The polymet cap is c 4517 with 4 pins and the one in question has no number with 4 pins but one has been cut off and I assume it is the yellow cap. Sorry the c4517 has the wire cut not the other one.
Also inter stage transformer has 5 wires and one not connected and here are the 4 connections - rf choke - rf choke - c 4517 - tone control not sure of one not connected
Top |
Tarpawns
Post subject: Re: Westinghouse model 801 grandfather clock radio. Posted: Aug Wed 28, 2019 10:27 pm |
Member |
Top |
spsquires
Post subject: Re: Westinghouse model 801 grandfather clock radio. Posted: Aug Wed 28, 2019 10:53 pm |
Hi your saying pacific tv is the one to use. That would be the link to the 16 pages I sent.
Top |
Tarpawns
Post subject: Re: Westinghouse model 801 grandfather clock radio. Posted: Aug Wed 28, 2019 11:10 pm |
Member |
spsquires wrote: Hi your saying pacific tv is the one to use. That would be the link to the 16 pages I sent. Yep...seems the best you have...Unless there's some other factory manual for the Columaire-8 which is out there.(I can't find it) ...It's identical to the one in RCC and pretty detailed...Suppose you could always contact Dave at Just Radios for factory lit if he actually had it. http://www.nostalgiaair.org/pagesbymode ... 030134.pdfKen
Top |
spsquires
Post subject: Re: Westinghouse model 801 grandfather clock radio. Posted: Aug Wed 28, 2019 11:15 pm |
I might do that or see what comes up here first.
Top |
spsquires
Post subject: Re: Westinghouse model 801 grandfather clock radio. Posted: Aug Thu 29, 2019 9:15 am |
Any more info or help on this radio would be great. Also how does one replace the cap blocks? Do you just take out all together stuff or jus leave in place and add new ones.
Top |
pixellany
Post subject: Re: Westinghouse model 801 grandfather clock radio. Posted: Aug Thu 29, 2019 8:38 pm |
Member |
I would restuff the capacitor boxes (there are 2) Note that the filters (electrolytic) are separate.
Top |
spsquires
Post subject: Re: Westinghouse model 801 grandfather clock radio. Posted: Aug Thu 29, 2019 8:48 pm |
The electrolytic are also in a metal can.
Top |
pixellany
Post subject: Re: Westinghouse model 801 grandfather clock radio. Posted: Aug Fri 30, 2019 12:46 am |
Member |
spsquires wrote: The electrolytic are also in a metal can. So--you can restuff that one also..... Almost anything is fair game if you can keep the same overall configuration and wire routing. For example, it's not good practice to put any part in a totally different chassis location.
Top |
Marcc
Post subject: Re: Westinghouse model 801 grandfather clock radio. Posted: Aug Fri 30, 2019 1:05 am |
Moderator |
Joined: Feb Sun 01, 2009 2:56 pm Posts: 11748 Location: Victoria, Australia
It is quite simple to restuff many of those cans, I normally line cans with insulation paper and as modern caps are smaller, that can make it easier. It can also mean that they can move around & short, so that has to be dealt with. The lining acts as a sleeve, should there be a need for future removal as well as restricting shorting to the can.
It is important to colour code the wires so that you can identify what is connected to what, especially when you get a can with more than eight in it. Silicone sealer makes a wonderful filler & binder but its insulation properties should never be relied on (not good).
There simply has to be a plan before touching anything.
Marc
Top |
spsquires
Post subject: Re: Westinghouse model 801 grandfather clock radio. Posted: Aug Fri 30, 2019 7:27 pm |
[ took the clock apart and cleaned it and it now works . Benched tested for a hour and keep time good. It has now been unplugged for a couple of hours and every now and then I still here it click once and awhile. Why?
Top |
spsquires
Post subject: Re: Westinghouse model 801 grandfather clock radio. Posted: Sep Sun 01, 2019 11:31 pm |
Going to attempt electrolytic can first. Now to figure out the connection points.
Top |
spsquires
Post subject: Re: Westinghouse model 801 grandfather clock radio. Posted: Sep Wed 04, 2019 12:02 pm |
Cabinet done but had to cut 6 inches off to repair.
Attachments: |
Top |
