It is currently Jan Fri 15, 2021 11:51 pm
Post New Topic Post Reply  [ 258 posts ]  Go to page 1, 2, 3, 4, 5 ... 13  Next
 Post subject: Westinghouse model 801 grandfather clock radio.
PostPosted: Aug Wed 28, 2019 3:11 pm
I have what I believe to be a Westinghouse model 801 columinair 8 grandfather clock radio and is looking for a good set of schematics.
 Post subject: Re: Westinghouse model 801 grandfather clock radio.
PostPosted: Aug Wed 28, 2019 3:27 pm
Radiomuseum has the schematic
PostPosted: Aug Wed 28, 2019 4:11 pm
I got that printed. Also found some info on pacific tv for just model 801 but the 801 looks to have more caps . Also here is chassis picture
PostPosted: Aug Wed 28, 2019 4:40 pm
Interresting the threaded shield cans. I found one on a home built equipment in some junk that I acquired. Wonder whats inside yours, mine had coils.
PostPosted: Aug Wed 28, 2019 5:04 pm
Mine is the two if transformers which will have coils.
PostPosted: Aug Wed 28, 2019 6:02 pm
Any help would be great has this looks to be a bit of mess. Here is a link.
http://pacifictv.ca/schematics/westingh ... manual.pdf
Page 14 shows all the cap blocks but do not match radio museum schematic has I will try to post
Radio museum
https://www.radiomuseum.org/r/westingca ... ire_8.html
PostPosted: Aug Wed 28, 2019 8:14 pm
What's the number on that capacitor pak (Polymet?) underneath that yellow capacitor on the left hand side on your set .....C4621?....And how many pins or terminals of it?....The other one is a C4517 or 4517 nearby?
Ken
PostPosted: Aug Wed 28, 2019 9:08 pm
The polymet cap is c 4517 with 4 pins and the one in question has no number with 4 pins but one has been cut off and I assume it is the yellow cap. Sorry the c4517 has the wire cut not the other one.
Also inter stage transformer has 5 wires and one not connected and here are the 4 connections
- rf choke
- rf choke
- c 4517
- tone control
not sure of one not connected
PostPosted: Aug Wed 28, 2019 10:27 pm
Here's a page from a service lit limited as it may be but it does state there are minor differences in the the table set and the Columaire. (can't read it I'll send it to you)
https://app.box.com/s/ekz14ss8leihsjf2e3mfmvtddzut5yda
https://app.box.com/s/5t4dvpmbv0xofagh42eqrnd1r1qekm0v
In some models the 4423 (and maybe 4517) (according to above) would of been dropped in favor of a 4621 capacitor pak. Someone else posted on here that they had both paks present the 4517 and the 4621 which is probably the same as yours.. I'd probably follow the schematic on Pacific TV since the're minor differences as this guy did. You already know what's in 4517 and how it's wired...
http://www.radio-antiks.com/IndexRadio- ... umaire.htm
They say they are similar to the R7 and R9 but you can see the're differences especially when it comes to the resistors.
http://pacifictv.ca/schematics/rcar7sch.pdf
Ken
PostPosted: Aug Wed 28, 2019 10:53 pm
Hi your saying pacific tv is the one to use. That would be the link to the 16 pages I sent.
PostPosted: Aug Wed 28, 2019 11:10 pm
Yep...seems the best you have...Unless there's some other factory manual for the Columaire-8 which is out there.(I can't find it) ...It's identical to the one in RCC and pretty detailed...Suppose you could always contact Dave at Just Radios for factory lit if he actually had it.
http://www.nostalgiaair.org/pagesbymode ... 030134.pdf
Ken
PostPosted: Aug Wed 28, 2019 11:15 pm
I might do that or see what comes up here first.
PostPosted: Aug Thu 29, 2019 9:15 am
Any more info or help on this radio would be great. Also how does one replace the cap blocks? Do you just take out all together stuff or jus leave in place and add new ones.
PostPosted: Aug Thu 29, 2019 8:38 pm
I would restuff the capacitor boxes (there are 2)
Note that the filters (electrolytic) are separate.
PostPosted: Aug Thu 29, 2019 8:48 pm
The electrolytic are also in a metal can.
PostPosted: Aug Fri 30, 2019 12:46 am
So--you can restuff that one also.....
Almost anything is fair game if you can keep the same overall configuration and wire routing. For example, it's not good practice to put any part in a totally different chassis location.
PostPosted: Aug Fri 30, 2019 1:05 am
It is quite simple to restuff many of those cans, I normally line cans with insulation paper and as modern caps are smaller, that can make it easier. It can also mean that they can move around & short, so that has to be dealt with. The lining acts as a sleeve, should there be a need for future removal as well as restricting shorting to the can.
It is important to colour code the wires so that you can identify what is connected to what, especially when you get a can with more than eight in it. Silicone sealer makes a wonderful filler & binder but its insulation properties should never be relied on (not good).
There simply has to be a plan before touching anything.
Marc
PostPosted: Aug Fri 30, 2019 7:27 pm
[ took the clock apart and cleaned it and it now works . Benched tested for a hour and keep time good. It has now been unplugged for a couple of hours and every now and then I still here it click once and awhile. Why?
PostPosted: Sep Sun 01, 2019 11:31 pm
Going to attempt electrolytic can first. Now to figure out the connection points.
PostPosted: Sep Wed 04, 2019 12:02 pm
Cabinet done but had to cut 6 inches off to repair.
Post New Topic Post Reply  [ 258 posts ]  Moderators: Norm Leal, Marcc Go to page 1, 2, 3, 4, 5 ... 13  Next
Users browsing this forum: AJJ, cokekid, jsloan999, jtiner, ke4vbg, mbruvry, Overland, SteveD and 38 guests
