Sure!
Bidder q***2 bid at least $8,000.00 (very likely more) in the first bid, realized their first bid hit the reserve of $8,000.00 (the "reserve met" is on the bidding page), and decided to up their proxy (their maximum bid) about 30 seconds later. Since you can't bid against yourself, the actual price stayed the same- only the max proxy amount changed.
q***2(private) US $8,000.00 12 Sep 2019 at 12:15:14 EDT
q***2(private) US $8,000.00 12 Sep 2019 at 12:14:43 EDT
Starting Price US $3,000.00 11 Sep 2019 at 16:41:23 EDT
Edit: I should amend my answer just a bit- if your first bid does not reach the reserve amount but your second bid does, the price jumps to the reserve amount. I believe this is the only circumstance where you can be the top bidder, place another bid, and have the price go up.
Edit 2: If you're leading by less than a full bid increment and bid again, the price will jump to a full bid increment above the second place bidder.
Ok, I'm done.
