It is currently Oct Thu 22, 2020 10:24 am
 Post subject: Dual 1009 questions
PostPosted: Oct Fri 11, 2019 9:25 pm
Currently cleaning and re-lubing this TT.... Two questions.... does the idler come off like most from the top? because it looked like a screw was on top but it is snapped off.... also are the 2 clamps the only thing holding the motor together? will brushes or anything come flying out if I try to split the clam shell of the motor?
 Post subject: Re: Dual 1009 questions
PostPosted: Oct Sat 12, 2019 2:43 pm
Here's the link to the service manual if that helps...https://www.vinylengine.com/library/dual/1009.shtml
PostPosted: Oct Sat 12, 2019 5:12 pm
Thanks ... I have the service manual , curious that the exploded view does not show a screw holding the idler on, maybe it is a over sight or somehow the whole shaft has to come out to get the idler off?...
PostPosted: Oct Sat 12, 2019 11:38 pm
Take the tip of your srewdriver and put it into the slot on the top of the idler support post. While putting downward pressure on the post, grab the edges of the idler from underneath and gently pull straight up. You will realease the plastic retainer ring and the idler will pull right out. The ring is reusable.
John Stone
PostPosted: Oct Sun 13, 2019 3:16 am
OK I will give that a try...
PostPosted: Oct Tue 29, 2019 1:16 am
The motor is of the hysteresis synchronous type so there are no brushes to worry about... to disassemble the motor, remove the screws/nuts/washers holding the brackets together, then wiggle the brackets free from the housing and set aside. Can then use a light hammer and drift to walk the cover off the motor field. It's a tight fit so move the cover just a bit at a time, alternating sides on which you strike the cover.
