It is currently Aug Thu 13, 2020 3:17 pm
 Post subject: Sony 4-203 external power supply
PostPosted: Oct Sun 27, 2019 7:38 pm
I recently restored (recapped) this set. What a job! I assumed that the battery pack delivered 12VDC, so I connected my 2 amp DC power supply to the rear of the set and turned it on. To my amazement, it produced a beautiful picture and sound! My question is: how do I replicate the power supply connection on the side of the set? I have no schematic and can't find one anywhere. I don't know what voltages are expected. There is a 3 prong connector. Is the input 12VDC? 12VAC? 117VAC? What's with the three prongs? Is one a ground? Thanks to all.
 Post subject: Re: Sony 4-203 external power supply
PostPosted: Oct Mon 28, 2019 7:02 pm
I have one of those sets and a schematic at home, via Sams photofact. Just type in sony 4-203 in your browser and there is a schematic there. It is a weird adaptor!
PostPosted: Oct Mon 28, 2019 11:56 pm
Tried Sony 4-203. The only schematic that came up was a partial one at radiomuseum. Does your schematic indicate the voltages at the three pins?
PostPosted: Oct Tue 29, 2019 4:38 am
This is part of the schematic from Radiomuseum that shows the power supply. 9 "C" cells gives 13.5 volts so the 12 volts you applied was correct. The AC supply is just stepdown transformer and a full wave bridge to provide approx 12 to 13.5 VDC. As you can see, only 2 of the 3 pins are used.
Tim
"One of the advantages of being disorderly is that one is constantly making exciting discoveries." A. A. Milne
PostPosted: Oct Tue 29, 2019 3:04 pm
Thanks! Just what I needed.
PostPosted: Oct Tue 29, 2019 3:55 pm
mstamper beat me to it! I found the Sams I had which is basically the same except it shows a bit more detail of the various power supply configurations used on this set. The unused pin was used as the ac adapter power to the rechargeable battery, which I have never seen. This is a marvelously overdesigned set for a tiny portable! 34 transistors, 5 tiny rectifier tubes (quintipular?) for high voltage supply. Three sound IF, three video IF, three agc amp stages, etc! And the crt filament is derived from horizontal "pulse" transformer!
Post New Topic Post Reply  [ 6 posts ]  Moderators: 7jp4-guy, Mr. Detrola
Users browsing this forum: Google [Bot], ken1 and 15 guests
