It is currently Jan Sun 26, 2020 10:45 am
 Post subject: Help ID these
PostPosted: Nov Fri 15, 2019 4:51 am
I am especially intrigued by no. 3.
No. 1 and 2 are the same tube.
Jeff, AC6S
 Post subject: Re: Help ID these
PostPosted: Nov Fri 15, 2019 5:25 am
The photo at the top certainly looks like a strobe tube, which flashes brightly when discharged.
The one at the bottom is a thermal time delay relay which closes or opens after a specific time.
PostPosted: Nov Fri 15, 2019 2:58 pm
Thanks Dennis.
Jeff, AC6S
PostPosted: Nov Fri 15, 2019 10:05 pm
As Mr Detrola says. The Grass type PST2100 is likely a Xenon flash tube. Grass made equipment like EEG machines (electroencephalograph). The flash tube was probably installed in a photostimulation accessory. You could for example stimulate certain patients who suffer from epilepsy seizures etc. The reactions would be recorded for evaluation.
David.
