Page 1 of 1
[ 13 posts ] |
Author |
transoceanic 8523
Post subject: Hardware Help For Mounting Loopstick Coils Posted: Dec Sun 22, 2019 9:22 pm |
Joined: Jan Mon 17, 2011 2:10 am Posts: 223 Location: Revere,Massachusetts U.S.A.
Hi Forum, I am always trying to find the correct material for mounting loopstick coils. I find a piece of metal and bend it into an "L" shape and drill out a larger hole for the stick...... I'm wondering if anyone has considered using a preformed "Plastic-L Shaped" I am looking at eBay and trying to find a plastic piece like used on brackets .....
Well any idea's on this should I just buy a small piece of sheet metal and suck it up ? or try a plastic piece?
I await your wisdom. Tony
_________________ I Love The Warm Smell Of Tubes In The Morning
Top |
processhead
Post subject: Re: Hardware Help For Mounting Loopstick Coils Posted: Dec Sun 22, 2019 9:42 pm |
Member |
Joined: Jul Tue 15, 2008 6:13 pm Posts: 8702 Location: Gretna, Nebraska
Considering that the ferrite rod is somewhat brittle, I would be looking for a mounting system that has some soft mounts for the actual stick. Maybe a couple of one-hole plastic cable straps attached to an aluminum L- bracket. You also might be able to incorporate a pair of rubber grommets in the system you described above to provide the same cushioning effect.
I think you want to avoid ferrous materials in close proximity to the loopstick to avoid any de-tuning. I am sure some others with additional ideas will chime in.
_________________ http://www.vintagerestorationservices.com Paul ...... how hard can it be?
Top |
mrx
Post subject: Re: Hardware Help For Mounting Loopstick Coils Posted: Dec Sun 22, 2019 9:50 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2918 Location: Massachusetts
Top |
mblack
Post subject: Re: Hardware Help For Mounting Loopstick Coils Posted: Dec Sun 22, 2019 11:26 pm |
Joined: Jun Sun 15, 2014 5:37 pm Posts: 731 Location: Montreal, Quebec
Take a piece of flexible plastic,like tge lid of a margarine or yogurt container, and cut a strip from that. Drill holes at each end, and wrap it around the loopstick. Then mount it with a bokt through the holes.
Top |
fifties
Post subject: Re: Hardware Help For Mounting Loopstick Coils Posted: Dec Sun 22, 2019 11:29 pm |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 36995 Location: SoCal, 91387
I wouldn't use any type of ferrous metal with which to mount a ferrite loopstick, as there could be some interaction. Use some form of plastic instead.
_________________ \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\He Who Dies With The Most Radios Wins/////////////////////////
Top |
transoceanic 8523
Post subject: Re: Hardware Help For Mounting Loopstick Coils Posted: Dec Mon 23, 2019 2:40 am |
Thank You to everyone who responded. I really appreciate it so very much. Happy Holidays Tony
Top |
Tim Tress
Post subject: Re: Hardware Help For Mounting Loopstick Coils Posted: Dec Tue 24, 2019 12:09 am |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 9804 Location: Beaver Falls, PA. USA
In the old days, they used plastic cable clamps. Sometimes, they were glued to a piece of "fish paper", which was mounted to the chassis.
_________________ Tim KA3JRT
Top |
Rich, W3HWJ
Post subject: Re: Hardware Help For Mounting Loopstick Coils Posted: Dec Tue 24, 2019 5:31 am |
Joined: May Tue 30, 2006 4:46 pm Posts: 10388 Location: Santa Rosa, CA
Top |
fifties
Post subject: Re: Hardware Help For Mounting Loopstick Coils Posted: Dec Tue 24, 2019 8:33 am |
Member |
Rich, W3HWJ wrote: Adjustable loopstick coils came with a metal mounting bracket. https://www.worthpoint.com/worthopedia/ ... 1431856580Rich Correct, and I built a few receiver circuits using them. However, the bracket fit right behind the (also) metal collar which retained the threaded shaft connected to the Ferrite core in a way that added minimal presence. And the core was adjustable, for any needed compensation.
Attachments: |
Top |
LM386
Post subject: Re: Hardware Help For Mounting Loopstick Coils Posted: Dec Tue 24, 2019 8:57 am |
I frequently use 2 pieces cut from a hot glue stick to support the loopstick or ferrite rod above the chassis. It is easily removable and may be made to look very pretty.
Top |
processhead
Post subject: Re: Hardware Help For Mounting Loopstick Coils Posted: Dec Tue 24, 2019 1:15 pm |
Member |
I guess I was thinking non-adjustable ferrite antenna coil in my earlier answer.
The adjustable ones like pictured above are obviously designed to me mounted in a hole in a metal panel.
Top |
John Bartley
Post subject: Re: Hardware Help For Mounting Loopstick Coils Posted: Dec Tue 24, 2019 3:05 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 9111 Location: 13 Critchley Avenue, PO Box 36, Monteith Ont, P0K 1P0
Why not use tye-wraps with the screw hole ?? Attachment:
Top |
Peter Bertini
Post subject: Re: Hardware Help For Mounting Loopstick Coils Posted: Dec Tue 24, 2019 4:22 pm |
Moderator |
Joined: Jan Thu 01, 1970 1:00 am Posts: 22181 Location: Somers, CT
Generally advisable to use non-ferrous metal near tuned circuits, less losses. The adjustable loop sticks had an aluminum L bracket. For solid ferrite bar antenna coils, plastic cable clamps can be made to work.
_________________ Just because it can be done doesn't mean it should be done.
Top |
Page 1 of 1
[ 13 posts ] |
Users browsing this forum: No registered users and 11 guests |
