It is currently Jul Sat 11, 2020 6:16 pm
 Post subject: Philco 41-300
PostPosted: Mar Sun 08, 2020 3:40 am
Fast forward several years and I finally recapped and replaced the resistors in my 41 Philco. all that’s left is the block near the power supply and two paper caps hiding in the volume control area ( I’ll get to them eventually). I replaced probably 90% of the resistors as they were all drifting high. When I bought it I was able to get ( poor ) reception from overseas. I plugged it in And aside from the dirty volume control which got better with use, the AM sounds very good. However, I don’t get and stations on the other bands, although I get the background static suggesting I should. The schematics for this set suck frankly, and from what I can read, none of the tubes seem to be specific to any particular band. and the few caps/ resistors left should be affecting AM as well as other bands if they’re are truly bad. has anyone worked on this set or have suggestions of what to check first? Could be as simple as needing an antenna? It’s been out of the cabinet for so long I could have even just not connected the antenna correctly but I’m not seeing any loose/ disconnected wires.....thanks! Christopher
 Post subject: Re: Philco 41-300
PostPosted: Mar Sun 08, 2020 3:46 am
Did you align it after replacing all those components?
PostPosted: Mar Sun 08, 2020 3:55 am
No I didn’t. I knew how to do that in high school but it’s been over a decade since I’ve done that - so I’d have to research how to do it again. You mean the IF circuit/ cans , right? Would that make such a difference?
PostPosted: Mar Sun 08, 2020 4:04 am
I'll put it this way. Aligning it could turn that static you heard into a clear station.
Yes, adding an antenna would help. In fact, most alignment procedures count on the alignment being done in the cabinet with the antenna attached.
PostPosted: Mar Sun 08, 2020 4:10 am
Is there anything in particular that triggers the need for an alignment? In the past I’ve only tended to replace caps ( and never really gotten any improvements from the few alignments I did) but this set had enough bad resistors that I decided to just replace most, I suppose that change in drift is enough to change reception.
PostPosted: Mar Sun 08, 2020 4:14 am
And since the AM is working does that at at least eliminate any of the IF cans?
PostPosted: Mar Sun 08, 2020 4:49 am
Yes there is. Replacing the majority of the components would constitute the need for an alignment. The more you swap out/changes you make, the more an alignment is needed. Alignment isn't just for improving reception either. It can help make the dial accurate if that has also drifted.
If an alignment didn't help in the past, then your radio may have needed more work, or you may have just screwed up a step. Human error is always a possibility. I've done it myself. As for needing more work, you may have to peek under those IF cans. Sometimes resistors and caps can hide underneath. I had a resistor inside one can of a Philco 40-160 I worked on a few months ago.
PostPosted: Mar Sun 08, 2020 7:25 am
This set apparently has four bands, BCB and three S/W. I would suggest switching it to the 9-12 MC band, tune to 10 megacycles, and see if you can get WWV. If not, connect as long an antenna wire as you can, and try for it. All bands are using both the loop, and have a connection for an external wire antenna.
AFA aligning, consider that component values drift over time, so alignment, both RF and IF, is indicated in order to do a professional job in restoration.
Here's a link to the service instructions, which include directions for alignment;
http://www.nostalgiaair.org/pagesbymode ... 013423.pdf
PostPosted: Mar Sun 08, 2020 6:20 pm
I had to look up what WWV is but I think I may have heard that last night, not really knowing any better. Wiki has a sample, and while I didn’t hear any voice playing over the air I heard an odd/ creepy ticking which was present in the sample audio. I’ll pay more attention today
PostPosted: Mar Sun 08, 2020 6:26 pm
I should also follow up with why would I be hearing that station but not others? What’s the significance?
PostPosted: Mar Sun 08, 2020 6:50 pm
So the wwv comes in weakly and blurry at 10kc. I also get something weak and blurry at around 16.5 kc in a foreign language. Does this sound like classic mid alignment !?!
PostPosted: Mar Sun 08, 2020 7:07 pm
A legible (printer friendly) service manual for model 41-300 can be downloaded from Tom Bavis' website, in DjVu format.
https://tinyurl.com/tom-bavis
I use this DjVu reader (safe download from sourceforge.net) works great.
http://antiqueradios.com/forums/viewtop ... 9#p2746819
:) Greg.
If you are using a Windows computer, here is a direct link to the DjVu reader .exe file.
https://sourceforge.net/projects/djvu/f ... rror=netix
Save it to your desktop, open it and follow the installation instructions.
PostPosted: Mar Sun 08, 2020 7:42 pm
I did a 41-300 a few yrs ago and it's one of my favorites. Great player and has a built in ant so you wouldn't necessarily need an external ant connected to it. As others have mentioned I would go thru and do the if and rf alignment and test the tubes. On my set the XXL's and 7B7's where pretty weak and made a big improvement when replaced. I'm not saying that this is an issue w/your set but it's a possibility. You will need to get a signal generator (if you don't have one) to do the IF alignment. https://philcoradio.com/phorum/showthre ... ght=41-300
Bear in mind any of the service literature was printed for the folks that made a living fixing these sets in the day when it was cutting edge technology. These guys could at a glance tell what did what and why a particular part was used rather than another in short they knew radios inside and out. It wasn't printed for hobbyist 70yrs later.
https://philcoradio.com/library/downloa ... 20Book.pdf
On all of the '300 schematics they are missing the connection from the vc to the output transformer. Pretend it's there.
Terry
PostPosted: Mar Sun 08, 2020 7:44 pm
I have a HealthKit SG 8 that I’ve never used so learning how to use it and will attempt my first legit alignment soon.
PostPosted: Mar Sun 08, 2020 8:33 pm
Two excellent alignment procedure videos (not found with a Google or YouTube search).
http://antiqueradios.com/forums/viewtop ... 1#p2645421
PostPosted: Mar Sun 08, 2020 10:03 pm
The WWV time signal consists of a ticking sound for the seconds, and then an announcement of the current time, continuously.
You had posted earlier that you were unable to get anything on the shortwave bands, so that's why I suggested that you try to dial in WWV, which is always there, and since it is in Fort Collins, Colorado, isn't too far away from your location. You might also try it on 5 Megacycles as well. It simply proves that your SW bands are indeed functioning.
There's no longer a helluva lot of broadcasts on SW, but you should be at least picking up a few signals. What exactly are you using for an external antenna, if you are, and in what time period are you listening?
AFA the tubes, I would suggest replacing the two XXL/7A4's, and the two 7B7's. I've generally found that replacing the converter and IF tubes usually marks an improvement in sensitivity.
PostPosted: Mar Mon 09, 2020 1:07 am
FYI, this may need to be recapped and aligned as well if it's never been done. Do you have a frequency counter? If not, you can get a cymometer off of eBay for cheap. Power it with a wallwart.
It's important that the signal generator is accurate as you will be assuming that the frequency that you're setting its dial to and using to align your radio is accurate.
PostPosted: Mar Mon 09, 2020 3:35 am
The generator's frequency output can be measured by simply using a digital readout AM radio. Set it to 910 kilocycles, and the generator to 455, then see if the radio picks up the tone on that second harmonic, with the generators hot probe next to the radio.
PostPosted: Mar Mon 09, 2020 3:51 am
Do not think anyone mentioned it but the loop antenna in the cabinet needs to be connected in addition to the external antenna.
Dale
http://www.dalesantiqueradio.com/
PostPosted: Mar Mon 09, 2020 6:14 am
Well my signal generator should be working correctly, I actually paid a guy to recap it and check out on the Oregon coast. However at the moment I can’t find the leads that go with it :shock: I’ll keep looking - hope I have it! I don’t have an external antenna and it’s currently in the basement if that might affect shortwave. The AM is working great. I’ve tuned the shortwave in in the morning and evening West coast time. Only 2 stations come in and are weak and blurry - I’m connected to the internal antenna.. I’ll have to see if I have spare tubes but may have to buy some. If the tubes were bad then I would assume AM would also be affected right? I’m not really seeing tubes/ parts that are totally specific to the shortwave, but I could be missing something.
Post New Topic Post Reply  [ 52 posts ]  Moderators: Marcc, Norm Leal Go to page 1, 2, 3  Next
Users browsing this forum: John Bartley and 19 guests
