Page 1 of 1
[ 7 posts ] |
Author |
rkeller
Post subject: Leader LDC 821S frequency counter Posted: Mar Sun 29, 2020 2:04 pm |
New Member |
Joined: May Tue 04, 2010 10:09 pm Posts: 9 Location: Wake Forest, NC
Picked up a “working” Leader frequency counter made in Japan. Going to clean, recap and calibrate, which seems pretty straight forward but can’t seem to find a any reference of, schematic of, nor manual for this nice little Nixie tube gadget. Tried all the normal places, here... bama... no joy. If any has a copy or any suggestions it would be greatly appreciated and I’ll share it here & upload. Thank you, Russ KM4RHK
Attachments: |
Top |
Barry H Bennett
Post subject: Re: Leader LDC 821S frequency counter Posted: Mar Sun 29, 2020 2:10 pm |
Member |
Joined: Nov Wed 30, 2016 7:35 pm Posts: 9420 Location: Sunbury, Ohio 43074
I'd reconsider a "recap" before you see if it's actually working. Obviously replace any electrolytics that are visibly leaking or bulging, and perhaps any wax/paper caps if it has those, but otherwise ... see if it works before going on the warpath would be my suggestion. A lot of test equipment used much higher grade components than consumer stuff, and may work just fine without introducing a ton of extra variables should something be NOT working. And I would absolutely not dive into the innards before locating a manual or at the very least, a schematic  my 2c.
_________________ Preserving the hist. of electronics, one boat anchor at a time! :) https://www.bbtvtestequipment.com
Top |
rkeller
Post subject: Re: Leader LDC 821S frequency counter Posted: Mar Sun 29, 2020 3:49 pm |
New Member |
You are probably right, I have dove right in the deep end before with less than stellar results. Thank you for that snippet of wisdom. Much appreciated. R
Top |
rv2p800
Post subject: Re: Leader LDC 821S frequency counter Posted: Mar Sun 29, 2020 6:21 pm |
Greetings from Norway  Hopefully my scan will be of help. I did change some electrolytic capacitors, the counter works fine - more for fun than use.
Top |
rkeller
Post subject: Re: Leader LDC 821S frequency counter Posted: Mar Sun 29, 2020 10:00 pm |
New Member |
Norway Leads one to nothing. Scan was good! Thank you very much.
Top |
Mikeinkcmo
Post subject: Re: Leader LDC 821S frequency counter Posted: Mar Sun 29, 2020 10:32 pm |
Member |
Joined: Oct Sun 15, 2006 12:57 pm Posts: 7542 Location: Liberty, Missouri
Thank you rv2p800, looks like that counter uses some MECL logic elements in the signal conditioning circuit. Looks to be from the mid/late 70s. No oven, but it'll be easy to zero beat with WWV and at room temp it should be plenty good enough.
_________________ Pics, Bold & underlined text, are usually links.
Top |
Wirelessme
Post subject: Re: Leader LDC 821S frequency counter Posted: Apr Thu 02, 2020 6:37 pm |
Thanks very much for posting the manual. I found one of these on Ebay a few weeks ago after searching for a couple of years, but no luck on a manual or schematic. Luckily mine worked fine on arrival. It needed a new line cord and a good cleaning on the outside otherwise in great shape. My first counter years ago was a nixie tube type and I'd wanted to find one just to look at I guess.
Top |
Page 1 of 1
[ 7 posts ] |
Who is online |
Users browsing this forum: Ford52PU and 25 guests |
