It is currently Jul Sun 12, 2020 7:01 pm
 Post subject: American Beauty 200w soldering iron
PostPosted: Apr Tue 07, 2020 10:16 pm
I have acquired an American Beauty 200w soldering iron. It works but I would like to replace the cord. The cord is functional but there is at least one spot where the cloth outer cord is worn through to the asbestos underneath. I know that there is a nut inside the wooden handle which should turn if you hold the body of the iron and twist the handle. Unfortunately it has been stored in damp conditions and I suspect there is some rust on the threads which prevents being able to turn the nut.
I suppose if I can't get it apart I could slide some shrink tube over the worn spot on the cord but I would rather replace the entire cord.
Any ideas or suggestions would be appreciated.
best regards,
Sandy
 Post subject: Re: American Beauty 200w soldering iron
PostPosted: Apr Fri 10, 2020 5:54 pm
Have tried to call American Beauty, they have been helpful in the past?
PostPosted: Apr Fri 10, 2020 5:58 pm
FWIR A-B has a repair service...
I priced a new 250 iron (an iron with a LARGE copper bolt) a while back. Just about a dollar a watt!
GL
PostPosted: Apr Sat 11, 2020 1:02 am
Thanks for the replies. I stood the iron with the tip up and introduced some penetrating oil down into the handle. From the diagrams I have found the oil has a reasonable chance of making it to the captive nut inside the handle. I'll leave it overnight and see if it helps.
I will check and see if a new handle is available. It would be easy to split the wooden handle and start over with a new one.
best regards,
Sandy
PostPosted: Apr Sun 12, 2020 2:24 am
I'm a bit surprised but the penetrating oil made it to where it needed to be and I managed to get everything apart without damaging anything. The plan is to clean it up and replace the cord. I already tested it and it works.
I've wanted one of these for a while and this was given to me by a friend who was cleaning out his shop.
best regards,
Sandy
Users browsing this forum: Barry H Bennett, targeteye and 24 guests
