It is currently Oct Mon 18, 2021 11:24 am
 Post subject: Россия 303
PostPosted: Aug Wed 26, 2020 12:47 am
Watched shango066's utube video on the Россия 303 recently, https://www.youtube.com/watch?v=XCm0XVrYt2U. Fur giggles I looked on the fleabay and found one fur $20, offered $10 and it is in the mail as we speak! Shango066 had problems finding a schematic fur it but one is readily available on the interweb. Not sure why I got it, hope I don't become part of any investigation... :wink:
In non-working condition, will post more about it when she gets up on the bench.
"It's amazing what you can accomplish when you throw safety out the window", Brent Butt
 Post subject: Re: Россия 303
PostPosted: Aug Wed 26, 2020 1:40 am
Service and user manual attached.
Удачи товарищ
:) Greg.
rossija303op.pdf [410.85 KiB]
Downloaded 68 times
rossija303rp_instr.pdf [541.77 KiB]
Downloaded 60 times
PostPosted: Aug Wed 26, 2020 1:45 am
But will it be able to receive English language stations? :wink:
PostPosted: Aug Wed 26, 2020 1:54 am
Может быть, Ричард, но люди в черном будут внимательно следить
8)
PostPosted: Aug Wed 26, 2020 3:12 am
I made a clean full size schematic with the transistor voltages if anyone ever needs it. :D
PostPosted: Aug Wed 26, 2020 3:53 am
Удачи товарищ
:) Greg.
Wow, had no idear there would be so much info on this radio. Thanks fur finding this. :D
PostPosted: Aug Wed 26, 2020 2:21 pm
Looks like it was made by Hershey's.
PostPosted: Aug Wed 26, 2020 3:05 pm
I didn't know that Hershey's has collaborated with the Soviets since 1974. This is more like a novelty radio made for Babaevskiy, the oldest Russian confectionery manufacturer (since 1804).
For reference, there are a lot of information for portable transistor radios produced in the former СССР and Российской Федерации at this site:
http://www.rw6ase.narod.ru/00/rp_p.html
More info for this particular model:
http://www.rw6ase.narod.ru/00/rp_p1/rossija303.html
Binh
PostPosted: Aug Sat 29, 2020 3:30 am
She came in the mail today! Powered it up and it actually works pretty well. The volume seemed kinda low so I started checking the electrolytics and holy macaroni, all but one were completely toast. The 100uF was the only one that was within reasonable specs. There was a 10uF that tested 13uF and 15 ESR. :shock: All the rest were zero capacitance. Amazingly it really didn't effect the radio with replacing them. Me thinks maybe a weak transistor somewhere or maybe it just isn't a very loud radio.
PostPosted: Aug Sat 29, 2020 8:12 am
Have you tried doing IF and RF alignments?
PostPosted: Aug Sat 29, 2020 4:29 pm
I don't think it's the alignment, brings in a lot of stations pretty clearly. I did miss one electrolytic that is encased in an aluminum shielded box. It has a separate pcb board inside that you have to desolder from the big board to be able to get at the pins on the bottom. Shango066 had some difficulty resoldering an IF can he removed so I am a little leery of removing it. I might try clipping the can off and soldering directly to the original pins. I haven't been able to find the alignment instructions yet but I haven't translated all the documents yet.
PostPosted: Aug Sat 29, 2020 5:05 pm
what are the cups for?
leakage containment?
i had a old russian radio come in a long time back.
all the caps were completely open.
the sets owner went to a few shops.
3 told him that they cant get service info so they wont touch it.
another said its useless anyhow as it wont tune modern english stations.
had to laugh and write a ticket.
so you will repair it?
sure its no different in design than any other transistor set!
PostPosted: Aug Sat 29, 2020 7:04 pm
Decided to try to replace this cap. Took a skill knife and cut out the plastic shield thingy then took a dremmel with a diamont point tip and cut the leads. The old cap tested open. :shock: Took the new cap, wrapped the leads around a piece of wire and carefully soldered it in the. Noise on the radio seemed to improve, very quiet and clear but I don't think the volume is as it should be. Read a Russian forum on them and one comment said how this thing boomed. If I am up to it tonight, will follow the signal path with my signal tracer and see if we find anything... :D
PostPosted: Aug Sat 29, 2020 10:31 pm
The type of variable capacitance tuner normally used has two gangs, with a trimmer capacitor for each one. Adjusting the one on the antenna gang at 1400 Kc usually increases the gain and volume level. I can't tell from the pics what type of tuner they use on this set though.
PostPosted: Aug Sun 30, 2020 12:31 am
if you touch the center (wiper) of the volume control do you get a loud hum?
PostPosted: Aug Sun 30, 2020 2:39 am
No hum, no noise just barely a click. What does that diagnose?
PostPosted: Aug Sun 30, 2020 5:18 pm
Another interesting thing I noticed. Before the recap on the DC power supply, it drew a steady 7mA. After the recap, it bounces between 7-14mA. One of the manuals says it draws 10mA max. Would a flaky transistor draw excessive bouncy current like this?
PostPosted: Aug Sun 30, 2020 6:38 pm
Ya... the longer the radio is on , the current steadily rises. It is up to 30mA after about 5 minutes.
PostPosted: Aug Mon 31, 2020 12:30 am
low gain in the amp.
problem is from the detector towards the speaker.
look for a leaky transistor since the current is high.
PostPosted: Aug Mon 31, 2020 12:38 am
Regarding the electrolytic capacitors in Soviet made radios, it has been my experience too that they are almost all open (or nearly so). The capacitors the Soviets used must have been poorly made, as most Japanese and US made 1970's capacitors are still usable, though not really trustworthy IMO (especially the filter capacitors on anything AC powered).
Post New Topic Post Reply  [ 26 posts ]  Moderator: Dave Doughty Go to page 1, 2  Next
