It is currently Jan Wed 19, 2022 10:49 am
Post New Topic Post Reply  [ 26 posts ]  Go to page Previous  1, 2
 Post subject: Re: Россия 303
PostPosted: Aug Mon 31, 2020 12:48 am
the plastic cups are still a mystery.
as for the one i repaired the client owned it as a kid and it slowly died off after 20 years.
he was in his 60'swhen he brought it in.
vintage u.s made sets seemed to lose their caps along the same time frame.
PostPosted: Aug Mon 31, 2020 3:58 am
Ok, I loosely coupled a loop antenna at a tuned frequency around 700kHZ with a 1k mod tone. Did a ballpark trace through the amp section. T5 on the schematic says its a MN41 and T6 a MN40 germanium but they both are the same silicon 0689 Russian transistors. I pulled T5 earlier today and it tested good with an hFe of 33 which is about what the germanium spec says. That T6 seems to have a huge gain so thinking maybe T5 though testing good is maybe weak? The voltages on the schematic below are pk-pk voltages from the scope reading. Also, waves going into T1 and T2 go in big and come out smaller, not sure if that is the way that is supposed to be. Volume turned to max.
"It's amazing what you can accomplish when you throw safety out the window", Brent Butt
PostPosted: Aug Mon 31, 2020 7:41 pm
t5 does not have much gain.
PostPosted: Aug Mon 31, 2020 9:40 pm
I swapped a 2N3906 and it made it maybe a tad louder... :oops:
PostPosted: Sep Thu 03, 2020 1:02 am
doesnt seem to be much signal from the detector.
diode ok?
weak if stage?
PostPosted: Sep Thu 03, 2020 2:30 am
diode ok?
weak if stage?
Been working on translating those PDF's and found a table of the signal path:
Looks like there should be much more gain from base of T5 to base of T6. My PCB board differs from the schematic around T5 like this:
Just bizzare... Something is either in the wrong place or this thing is just relatively quiet. I was wrong about one thing, it idles at max 10mA with max draw of 100mA. I screen shoted Shango's board and everything looks the same component wise but some jumper wires are in different spots.
Mine:
Shango's:
Post New Topic Post Reply  [ 26 posts ]  Moderator: Dave Doughty Go to page Previous  1, 2
