It is currently Apr Mon 19, 2021 7:44 pm
 Post subject: SX-42 Wiring Question
PostPosted: Nov Fri 27, 2020 2:54 pm
Working on a new to me SX-42. Lots of parts had been replaced and the radio was "supposedly" working. Well I'm finding many parts still need to be replaced and previous workmanship left a lot to be desired - but I digress.....
For reference this SX-42 is built to the "G" schematic.
Working on the 3rd IF xfmr wiring. There is a shielded wire that comes from the BFO and ends at a terminat strip near the 2nd IF tube. The schematic shows this point to be capacitivly coupled 3rd IF xfmr pin 5. There was not a connection from the terminal strip to pin 5.
Question is where should I make this coupling? I understand what the "gimmic" cap is just need to know where to best make the connection and how many turns?
Hopefully the pics help explain what I'm asking.
W3TA
 Post subject: Re: SX-42 Wiring Question
PostPosted: Nov Fri 27, 2020 6:45 pm
It looks to me that the shielded conductor in your schematic just diagrammatically crosses over the conductor going to the gimmick capacitor, and is not connected at all (unless I am misunderstanding your question...)
PostPosted: Nov Fri 27, 2020 7:04 pm
The shield is shown in the schematic on the wire in question but does not show in the snippet of the schematic I posted.
W3TA
PostPosted: Nov Fri 27, 2020 10:05 pm
After looking at this for a while I think the "crossover" IS the gimmick capacitor (see green and blue crossing below).
In other versions of the schematic it shows up as a 7 pF capacitor (very, very small).
It is just the coupling of the BFO signal into the detector.
Curtis Eickerman
PostPosted: Nov Fri 27, 2020 11:30 pm
I had the same setup on the SX-11 I was working on, the BFO never really worked correctly until I replaced the
(apparently non-existent gimmick) with a 250 pf silver mica, which I then upped to 330.
If your BFO is not working well simply start with around 100 pf and work your way up from there, I would say.
PostPosted: Nov Sat 28, 2020 12:44 am
[/quote]After looking at this for a while I think the "crossover" IS the gimmick capacitor (see green and blue crossing below).In other versions of the schematic it shows up as a 7 pF capacitor (very, very small).It is just the coupling of the BFO signal into the detector.
Curtis Eickerman[/quote]
Interesting observation Curtis. I'll need to take a closer look at that area.
PostPosted: Nov Sat 28, 2020 12:45 am
I'll keep this in my back pocket, thanks!
W3TA
Post New Topic Post Reply  [ 7 posts ]  Moderator: Sandy
Users browsing this forum: Sandy, WoodchuckTN and 8 guests
