It is currently Sep Sat 18, 2021 7:36 am
 Post subject: Reisstor bands
PostPosted: May Tue 25, 2021 10:23 am
Hi there,
Can someone tell me what the bands in this resistor are? I see red, black, gold but I am not sure. It measures 24.7 Ohms and if my vision is correct, that reading is off.
 Post subject: Re: Reisstor bands
PostPosted: May Tue 25, 2021 11:40 am
Hard to see in picture from far away. But looks like red red black gold or 22 ohm 5%.
Scott.
PostPosted: May Tue 25, 2021 11:45 am
Definitely need a better close up picture in good natural light.
PostPosted: May Tue 25, 2021 12:15 pm
That's because I could not find the proper setting in my camera.
I am attaching two good pics and a resistors color table in which the bottom line shows red-black-gold.
I thought that if that was red-black-gold, the value should be 20 Ohms but according to the table the gold means a multiplier of 0.1 which would mean the 20 becomes 2.0. Any clarification?
However, even if it were 20 with a 5% leeway, the measured value of 24.7 should indicate the resistor is gone, correct? It is connected by the way to a zener diode in a transfromer/stepdown of 220VAC/9VDC.
PostPosted: May Tue 25, 2021 12:20 pm
Hi Scott,
So you are in peaceful Montvale and most likely we crossed paths in some ham fest when I lived in NJ.
PostPosted: May Tue 25, 2021 12:43 pm
Yes, Red Red Black Gold: 22 ohms, 5%
Yes, 11% off but probably still works.
Scott.
PostPosted: May Tue 25, 2021 1:36 pm
If you want to measure a low value resistor like this accurately you have to subtract the lead resistance when using a DMM. With VOMs and VTVMs this is taken care of when you zero the meter out, but most DMMs don't have the means to do this.
If you have a DMM, short the probes together and note the reading. You will probably get a number around 0.7 ohms. Some will be a little higher, some a little less. That number is to be subtracted from whatever it reads when you measure the resistor. So your 24.7 ohm resistor is probably more like 24 ohms. 24/22 = 9% over marked value. The gold band means 5% tolerance, so technically it is out of spec but not so far out that it should cause the circuit you describe to malfunction. Resistor values only hold when measured at a specific temperature, nominally 25 degrees C (77 degrees F) so if the temperature was different--say you just unsoldered it and it was still considerably hotter than room temperature when you measured it--then it could read higher.
If the resistor is in series with a Zener diode in a power supply circuit of some kind, a couple more ohms might actually be advantageous, since that would tend to lower the current through the diode, helping it to last longer.
PostPosted: May Tue 25, 2021 5:40 pm
Thanks, I will try to measure it with two more meters but how does the multiplier works because if we multiply 20 by 0.1 for gold we get 2.0 Ohms.
On a related issue, I have to replace two axial electrolytics ( which was the reason I got curious about the resistor), one is 470/10, the other 2000/18 but I can not find axials here so I have to go with radials. That poses a problem because the large cap goes sideways on the back of the board and measures an inch in length which means that I can not use a radial because its leads do not spread that much unless they are long enough. So, if I solder the cut-off leads of the old cap to one or maybe both leads of the new, radial, cap, will the capacitance be affected significantly?
PostPosted: May Tue 25, 2021 5:45 pm
Gold is the tolerance. Black is the multiplier.
PostPosted: May Tue 25, 2021 5:52 pm
Colors are Red, Red, Black, Gold. Black is multiplier (x 10^0), gold is tolerance (5%). So 22 x 1, 5%, 22 ohms.
As said, short the meter leads to see what the DMM reads and subtract that from the actual reading.
No, lead capacitance only matters when you get down to picofarads.
Scott.
PostPosted: May Tue 25, 2021 9:29 pm
Note that your resistor has TWO red bands!! So it's not "Red, Black, Gold" it's "Red, Red, Black, Gold"
Faith is ... a belief in things not seen. (Heb 1:1)
PostPosted: May Wed 26, 2021 12:43 am
radioer wrote:
Hi Scott,
Not so peaceful anymore. They have built so many high density housing units in this area that many towns are more like cities now. The traffic is nuts and I can't wait to get out of here. Heading down to NC real soon.
PostPosted: May Wed 26, 2021 7:46 am
What a shame. I used to drive through that area on Sunday afternoons to enjoy nature and peace.
Good luck.
