It is currently Sep Tue 28, 2021 1:56 pm
Post New Topic Post Reply  [ 39 posts ]  Go to page Previous  1, 2
 Post subject: Re: Construction 3 tubes Audion 1923, all concert, patent Au
PostPosted: Apr Sun 04, 2021 9:06 pm
Chas wrote:
mrx wrote:
anyone know what value the variable tuning capacitors should be? the article does not list it.
Go Here:
https://www.antiqueradios.com/forums/vi ... 1&t=342931
and here:
https://www.antiqueradios.com/forums/vi ... 1&t=344081
The Deforest resonated the coils with a 1000pf variable cap. The tuning ranges in meters are given to the coils in that combination. The resonance for other variable caps can be found by either calculation or from a chart in ALFRED A GHIRARDIs Radio troubleshooters handbook... chas
Andrew
PostPosted: Apr Sun 04, 2021 9:10 pm
You do some exceptional work, Jan. Just beautiful.
Your workmanship probably exceeds any of the factory versions of this model.
Paul
...... how hard can it be?
 Post subject: Forest? Armstrong? Audion 1923, all concert, patent Audion
PostPosted: Apr Mon 05, 2021 10:50 am
yan_sk wrote:
Greetings colleagues, The above shown receiver design is not a replica. It is an implementation according to the instructions printed in 1923 in the magazine RADIOAMATÉR, this is the first information published in the press about this type "all concert" of receiver in Czechoslovakia. Here is my effort to design a receiver after almost a hundred years.
You can see the construction process,
https://youtu.be/NZEb_q1iN38
next part
https://youtu.be/7ieXicobT54
Regards
Jan
In connection with the construction of the audion/oscillator, I read a lot about the discovery of Lee de Forest and Edwin Howard Armstrong. I know how it was formally decided until the sad end of E. H. Armstrong. But Armstrong has more sympathy, what was the main problem? Are there any documents for that?
Jan
PostPosted: Apr Tue 06, 2021 12:52 pm
Chas wrote:
Go Here:
and here:
Will have to get a copy of the book, looks like he is using 500MMFD variable caps.i
Andrew
 Post subject: Re: Forest? Armstrong? Audion 1923, all concert, patent Audi
PostPosted: Apr Tue 06, 2021 12:53 pm
next part
Regards
Jan
Jan
Have you looked at the https://worldradiohistory.com/ website, lots of resources there.
Andrew
PostPosted: Apr Tue 06, 2021 2:26 pm
mrx wrote:
Chas wrote:
Go Here:
and here:
yes, in the manual the antenna capacitor is 1000pF and the anode 500pF. Or 500pF and 300pF. Of course, as a colleague writes, it is a resonant frequency, ie the choice of inductance and capacitance.
PostPosted: Apr Tue 06, 2021 3:40 pm
yan_sk wrote:
...yes, in the manual the antenna capacitor is 1000pF and the anode 500pF. Or 500pF and 300pF. Of course, as a colleague writes, it is a resonant frequency, ie the choice of inductance and capacitance.
From what I have in a "broken" honeycomb coil sets, most are marked with the number of turns. I also have a a couple of flat "spiderweb/pancake" coils that are configured with the M/F connector, some are home made. It is possible for a Morris coil winder to create up to a 250 turn coil. Beyond that the wire gauge has to be reduced and the wire waxed to keep it from sloughing off the during the build of the coil. The layout of the components will dictate if the radio can get into the shortwaves. My coil collection has a couple of 35 turn coils. With a 500pf variable and coils with fewer windings is should be possible to get to 80 meters. The determining factor is losses in both the coil and the larger variable condenser. The coil collection consists of Branston, Coto, DeForest, Giblin and "No-Names" of 35 up to 2500 turns, heavy... Some of the coils use both celluloid and leather parts. The leather has dried, hardened and broken and the celluloid is slowly decomposing and creating acids that is eating at the turns, The celluloid is the form for the 35 turn coil... chas
PostPosted: Apr Sat 10, 2021 9:15 am
Chas wrote:
Go Here:
and here:
uf ..., Forest MR6 is a wonderful device, coils about as much, getting originals is always a problem, for some reason they are almost never complete with a radio. It's nice to have at least some originals, they can be repaired, or at least replicas can be made.
regards
Jan
PostPosted: Jun Mon 14, 2021 7:06 pm
Do you have any construction pictures or advice?
Your craftsmanship is superb. I think there would be a great deal of interest amongst are fellow forum friends!
Peace,
DrRick
PostPosted: Jun Mon 14, 2021 8:42 pm
Peace,
DrRick
Building my own over the winter (the american version, using stock radio parts), think I have all the parts. Laying out the panel will be tricky, as it seems small when you load it up, maybe need another 1" or so.
Andrew
PostPosted: Jun Wed 16, 2021 8:29 am
Peace,
DrRick
Thank you, I am pleased with your interest. For these devices, the dimensions are given in the manual, but this must be taken as a recommendation. It always depends on the components used and especially on those that can now be obtained or manufactured.
A reference to the instructions in the RADIOAMATER 1923 magazine is given in the previous comments.
PostPosted: Jun Wed 16, 2021 8:33 am
yan_sk wrote:
Peace,
DrRick
an addition, our magazine probably drew from the source https://worldradiohistory.com/UK/Modern ... -S-OCR.pdf
PostPosted: Jun Sat 19, 2021 6:20 am
Really Nice!!
PostPosted: Jun Mon 21, 2021 1:50 am
Yan,
What are the values for the capacitors k1 and k2.
Andrew
PostPosted: Jun Mon 21, 2021 4:09 am
Wow that is beautiful.
Electronics are filled with smoke. It’s my job to put the smoke back in when they fail.
Cheers,
Jay
PostPosted: Jun Mon 21, 2021 1:09 pm
mrx wrote:
Yan,
thank you for your interest, k1 about 200-400pF, k2 1-1.5nF.
PostPosted: Jun Mon 21, 2021 1:12 pm
thank you for your appreciation
PostPosted: Jun Mon 21, 2021 1:26 pm
PostPosted: Jul Sun 04, 2021 3:02 am
if building your own would you use metal or bakelite binding posts, both seem period correct.
Andrew
