It is currently Nov Mon 29, 2021 6:38 am
 Post subject: Bluetooth, AM Transmitter
PostPosted: Aug Fri 06, 2021 5:20 pm
I have a difficult time listening to ads and DJ's babbling on about crap that I don't care about, so I decided to add Bluetooth to the Pioneer SX-203 that I use in the garage. I designed and etched a circuit board, built it up, then printed a case for it on the 3D printer.
It works well and I know I'm going to enjoy it, but what I'd really like to do is build a low power AM transmitter that can be modulated with a Bluetooth module. That way I can play my music on any of my old radios without adding a Bluetooth module to each. I did build a transmitter and it worked, but was very noisy, and I'm not smart enough with that stuff to figure out why. Can someone point me to a relatively simple circuit that I could tinker with?
My name is not Craig...look closely. cr = Cedar Rapids, ia - Iowa, geek = geek
 Post subject: Re: Bluetooth, AM Transmitter
PostPosted: Aug Fri 06, 2021 6:18 pm
Hey Rich,
Nice job on the Bluetooth module, I have tons of cheap Chinese Bluetooth boards that run off 3.7v. They are fun to play around with.
Funny you mention an AM transmitter I was looking into building one myself.
There was a thread a while back in the homebrew section about a Transmitter like this one, https://www.ebay.com/itm/313150374853?h ... SwChpfEX9E
You might get more responses if this thread was in the homebrew section.
Henry
PostPosted: Aug Fri 06, 2021 8:50 pm
Thanks Henry! That transmitter you linked looks like it is probably this circuit, with a choice of 3 crystals:
https://scitoys.com/transmitter.html
I tinkered with that and never got satisfactory results. I ordered the kit from Sci-Toys but I'm thinking that the transformer they sent isn't well suited to this purpose.
Where do you get your Bluetooth modules? I got mine from Amazon and they run on 5v.
I was uncertain where to put this thread...homebrew seems like a reasonable suggestion. I assume a mod has to make such moves...can someone help me out?
PostPosted: Aug Fri 06, 2021 10:18 pm
Looks like Dave took care of moving it.
One thing I have noticed about the sci-toys websites projects is that there kinda optimistic about their designs. Once I attempted to build a crystal set from them and there was no option for a ground or antenna and were talking a coil, diode, and headphones, simple...
I get my boards from eBay and they look like this- https://www.ebay.com/itm/264403541721?_ ... Ui3SFIwsLG
Once I stuck one in a cheap low-value Hong Kong Transistor radio and used the original VC control as a switch. So I can use it without opening up the case. Looks neat.
I am interested to see what you find out.
Henry
PostPosted: Aug Fri 06, 2021 10:42 pm
Here's the homebrew TX thread. Uses fixed frequency oscillator modules driven by an LM386 as the modulator. I have a small supply of oscillators for several different frequencies if you decide to go that route.
PostPosted: Aug Sat 07, 2021 1:49 am
Thanks hwhall - did you forget to post the link?
PostPosted: Aug Sat 07, 2021 1:56 am
Looks like I did forget the link!
viewtopic.php?f=12&t=193042
PostPosted: Aug Sat 07, 2021 2:10 am
Thanks hwhall!
