It is currently Jan Tue 25, 2022 12:23 am
 Post subject: Short antenna capacitance
PostPosted: Aug Mon 16, 2021 12:10 am
I want to understand is how to calculate the self capacitance of a simple Part 15 antenna wire.
On my LM386 transmitter, the final is an MPSA18 NPN transistor. The collector is fed by the LM386 through a 2 mH choke. The collector also goes to the antenna via a 157 uH coil shunted to ground on the antenna end by a 4 pF capacitor, peaking at 1680 KHz.
Resonance calculators say the capacitance must be 56 pF. So where's the other 52 pF? Does the wire antenna have that much capacitance? Does the capacitance in the transistor figure in? If so, what part of the transistor contributes to the capacitance stack? THANKS.
If a stranger sits next to you, stare straight ahead and say, "Did you bring the money?"
 Post subject: Re: Short antenna capacitance
PostPosted: Aug Mon 16, 2021 12:31 am
https://badw.de/fileadmin/members/R/368 ... tionMJ.pdf This article points out that electrically short antennas can easily amount to 25 pF/meter. So a 6 to 10 ft antenna could easily amount to a capacitance in the range you are estimating.
Curtis Eickerman
PostPosted: Aug Tue 17, 2021 6:15 pm
Here you go: https://www.everythingrf.com/rf-calculators/whip-antenna-calculator
Here's a sample using a 118" (~3 meter), 1/8" dia. rod at 1680Khz:
― R. A. Heinlein
PostPosted: Aug Tue 17, 2021 6:59 pm
Well, there you go. I love definitive answers. I can see exactly where that missing capacitance is. THANKS Curtis and John.
