It is currently Jan Sat 29, 2022 8:38 am
 Post subject: a source for Oldaker Mfg. Corp. military surplus test leads
PostPosted: Aug Tue 31, 2021 6:32 pm
Somebody on eBay has a pile of Oldaker military test leads for sale. They are somewhat similar to the Elwyn military surplus lead kits, in that they have an assortment of screw-on tips. Unlike the Elwyns, the meter end of these leads is just tinned wire - you'll need to supply your own banana plugs or pin plugs.
I've no financial interest, just a satisfied customer glad to find some cheap Oldaker test leads (the seller does combine shipping).
The ones I received were in good condition. The alligator clip tips were a bit tarnished, but everything else was perfect.
https://www.ebay.com/itm/400177860683
 Post subject: Re: a source for Oldaker Mfg. Corp. military surplus test le
PostPosted: Sep Wed 01, 2021 3:07 am
Vinyl or rubber wires? I had some sets of those mil spec test leads. One spare kit sat disused for a long time and eventually the rubber wire started crumbling. Otherwise they are nice and I have a set on one of my bench meters.
PostPosted: Sep Wed 01, 2021 11:54 am
They are rubber, nice and flexible. I've have one case where the rubber on one of the leads on my AN/URM-105C VOM disintegrated, but the other lead was and still is fine. Otherwise I haven't had any problem with rubber-insulated test leads, military surplus or not.
PostPosted: Sep Sat 04, 2021 3:31 pm
Nice! Just ordered a couple of sets for a Heathkit MM1 VOM restoration.
PostPosted: Sep Sun 05, 2021 12:49 am
I have some spools of red and black rubber test lead wire, I believe it is Belden made, and it held up quite well in my work shop as well as at home. And I have seen that where certain colors of rubber wire disintegrate more than others in the same vintage or make. Broke my heart once to open a nice shiny new looking brown pack of mil leads and find crumbly junk. But they can sometimes be restored and the attachments are always good to use.
Users browsing this forum: lkopvbgf786 and 16 guests
