It is currently Dec Sun 05, 2021 7:04 pm
 Post subject: Spider coil forms
PostPosted: Sep Mon 06, 2021 1:20 am
Does anyone know where spider coil forms can be found? I know pebbles used to sell them,but I understand they are no longer taking orders. If I have to make my own what materials can I use? Does it have to be plastic or could I use thin plywood or cardboard?
 Post subject: Re: Spider coil forms
PostPosted: Sep Mon 06, 2021 1:46 am
would have to be rigid, plastic, bakelite, masonite, phenolic, CDROM, etc... Crosley and others used cardboard, although I think you would have to impregnate it to make it stable and rigid.
Andrew
PostPosted: Sep Mon 06, 2021 4:27 am
Is this for crystal radio? If so you want to minimize your losses. High Density Polyethylene (HDPE) has less loss than just about any other material. For example, cardboard (paper) has a dielectric constant of 3.7 while polyethylene is 2.25.
Does anyone in your family have cats? Cat litter containers produce sheets of it big enough for a spider coil. The 40 lb containers are rigid enough to be used single ply. The 20 lb containers may need to be doubled or tripled up.
Also you can use a corrugated election or garage sale sign. Harder to cut cleanly, though.
PostPosted: Sep Mon 06, 2021 4:55 am
this guy has been trying to sell these for awhile
https://www.ebay.com/itm/265243631223?h ... SwOyVg~1pw
Andrew
PostPosted: Sep Mon 06, 2021 3:23 pm
Thanks for the suggestions guys,I'll probably use Masonite . I use it all the time for radio chassis and panels.
PostPosted: Sep Mon 06, 2021 4:04 pm
Hey Jimbob,
Masonite used as a coil form may be fairly lossy. On a good antenna /ground , it "should" work on local strong stations.
If you are going for any type of Dx, I might shy away from Masonite and go with a formless basket weave or other type of coil.
Will you actually NOTICE and HEAR a big degrade with Masonite forms- "maybe".
FWIW, ie with the Crosley Model 50, the coils are wound on wooden dowel "spokes" that radiate from a center hub.You'll notice that the wire has a somewhat restricted direct contact with the dowels. There is a lot of AIR in the coil ( a good thing :D ). IMHO- In ANY type of coil form : the less coil form /wire contact , the better.
In a crystal set (if that's what you're building) EVERY theoretical loss should be minimized. Multiple sources of loss within the "stages" can add up ( ie type of coil form used, det/tank Z match, det phone Z match, etc, etc, etc.). In an amplified set, particularly one that has RF amplification, it might not be so critical.
So it depends. I sometimes intentionally use "less than optimal" techniques for construction convenience or simply for looks.
K
PostPosted: Sep Tue 07, 2021 7:03 am
I have used the plastic CD "protectors" and cut them on the bandsaw.
Even used a butter lid to prove it can be done.
PostPosted: Sep Tue 07, 2021 11:06 am
Here is a link to what is used in the Antique Wireless Association's Radio Fab Lab, which is an excellent hands-on program for ages 8-15. The coil forms are laser cut in acrylic or polycarbonate...no attempt is made to reduce RF losses.
http://awa.canadice.net/
AWA's Radio Fab Lab is getting ready to start with several new classes for area youth, which include an Introduction to Analog and Digital Computers and Build an AM/FM Radio.
73 Dean
PostPosted: Sep Wed 08, 2021 12:46 am
I always wanted to try tinker toys. The only drawback is that they only have an even number of spokes. An odd number would help with stray capacitance.
Mark
PostPosted: Sep Wed 08, 2021 6:24 pm
Hey Mark,
GREAT to see you in here. It's been a LONG time !!!
I too was thinking Tinker Toy for reproducing a Crosley type coil. I forgot how many spokes it had though.
One could drill press out a section of a wood and glue in very small radial dowels (I suppose ). Personally I usually go 13 point basket weave formless and call it a day .
de N1NQC
PostPosted: Sep Sat 18, 2021 9:12 am
How about plexiglass or lexan? Micarta? Where can I look up their dialectric characteristics?
PostPosted: Sep Sat 18, 2021 6:16 pm
Extensive list of Dielectric Constants.
https://www.clippercontrols.com/pages/D ... alues.html
PostPosted: Sep Sun 19, 2021 10:48 am
Thank you very much!
