It is currently Dec Tue 07, 2021 3:41 am
 Post subject: WTB - UV-200 Detector Tube
PostPosted: Sep Mon 06, 2021 1:42 am
I'm looking for one good UV-200 BBT (one amp) detector tube for a radio in my collection.
Dan
Museum Curator
 Post subject: Re: Deleted
PostPosted: Sep Mon 06, 2021 2:24 am
This guy on ebay was selling a bunch of deforest tubes in May, https://www.ebay.com/usr/chsales10
check with him.
Andrew
 Post subject: Re: WTB - UV-200 Detector Tubes
PostPosted: Sep Mon 06, 2021 2:30 am
Hi Andrew, you must have been posting right as I was changing my post to another tube type. :D
Dan
Museum Curator
PostPosted: Sep Mon 06, 2021 2:54 am
Cross your fingers regarding what you may receive. If they have been previously tested as 01-A's, they aren't likely to function correctly. Others, including me, have tested 00-A's incorrectly in the past. I have several 00-A's and I am not aware of a way to separate those I tested incorrectly in my early days of collecting from those acquired after I was made aware of the danger of testing them with 01-A higher B+ settings. I wouldn't be able to offer any that I could certify as tested with 00-A data. When I will be installing them in my battery sets I will be cycling through my supply to see which ones appear to be operating correctly. I am not aware of any way to determine which I may have spoiled back in the 70's. If someone here has a reliable method to determine 00-A's that are not damaged from incorrect testing procedure, that could be helpful.
PostPosted: Sep Mon 06, 2021 3:17 am
I'm looking for 00's not 00A's, just to be clear.
Dan
Museum Curator
PostPosted: Sep Mon 06, 2021 3:27 am
I did, only have one 00 tube NIB, which I am saving.
Andrew
PostPosted: Sep Mon 13, 2021 3:36 pm
Bump
Dan
Museum Curator
PostPosted: Sep Mon 20, 2021 2:15 pm
Bump
Dan
Museum Curator
PostPosted: Sep Tue 28, 2021 12:21 am
Bump
Dan
Museum Curator
PostPosted: Oct Wed 06, 2021 2:56 am
Bump
Dan
Museum Curator
PostPosted: Oct Wed 20, 2021 3:29 am
Bump
Dan
Museum Curator
PostPosted: Oct Sun 31, 2021 2:11 am
bump
Dan
Museum Curator
PostPosted: Nov Fri 05, 2021 5:00 pm
Bump
Dan
Museum Curator
PostPosted: Nov Sat 13, 2021 4:33 am
Bump
Dan
Museum Curator
PostPosted: Nov Fri 26, 2021 7:26 pm
Bump
Dan
Museum Curator
Post New Topic Post Reply  [ 15 posts ]  Moderators: Alan Voorhees, Philco Fan
Users browsing this forum: bluebellyyankee, Chuck McB, dsturz, edison64, philco 40-165k and 7 guests
