It is currently Jan Mon 17, 2022 6:21 am
Post New Topic Post Reply  [ 36 posts ]  Go to page Previous  1, 2
 Post subject: Re: Homebuild Reinartz tuner amp.
PostPosted: Apr Wed 21, 2021 9:21 pm
Pictured rheostats all the same brand and all are at 0.8ohm , the original ones in the radio are all at 0.8ohm . im unsure of transformers its been a while ,im unsure because i cant read the punched numbers to test? the ones in my deforest d10 gave me a fit....
PostPosted: Apr Wed 21, 2021 9:56 pm
Um, that does not sound right, it is rare that less than one ohm used and it would control several tubes in the radio... Check the ohmmeter used or try another ohmmeter... chas
PostPosted: Apr Wed 21, 2021 11:39 pm
Did all readings at 1k 0.8 ohms , tried again at 10k and it reads 2. my ohmeter is cheap, digital wont work on rheostats im pretty sure, i did try it and there was 1500 for a second on digital.
PostPosted: Apr Thu 22, 2021 12:12 am
If you can borrow another ohmmeter try measuring the rheostats again. However, 2 ohms sounds correct for a rheostat used with a 1 amp tube... If the three spare rheostats also measure 2 ohms there is no point in using them either. When the power supply is connected, the effect of the existing rheostats will be known...
PostPosted: Apr Thu 22, 2021 8:06 am
I was going to see if there was any static from the headphone jacks, but im unsure where to plug them in, but after looking at most Reinartz schematics, im more than confused..i thought i needed a few wire contacts on the front panel from the detector to the amp..and the 3- 1/4 inch jacks on the front have me scratchin my head.
PostPosted: Jul Tue 13, 2021 1:56 am
Update....original .Federal No -20 transformers..Secondaries are good-primarys are open.new .replacements? i have 2 good 1920s transformers Erla 6-1,kellog 3-1 but wont fit..should i just make a new platform and start anew? leave the original amp-till i can get the transformers rewired.... got 2 good grid leaks with condensors.finally bought a arbe iii needed one for the last 35yrs :oops: .
PostPosted: Jul Tue 13, 2021 5:32 am
Yes, a new breadboard to fit the larger transformers.
Scratching the head, why grid leak(s) this is an Amp not a detector...
You see the chart above is for the correct value of rheostats to use.
I note you have an analog meter. Great!
Chas
PostPosted: Jul Tue 13, 2021 6:01 am
G,day Chas and everyone , the grid leak is for the detector- if i need one ? .., it had only a dubilier micadon 1921 .00025mfd when i got it....i will go to a buddys place and cut a platform, i have a few panels i can cut- use for the new face-platform, im wanting this radio to stay almost the way it was built in 1921,but want to use it until i find someone to wind the original coils, leave it correct,no hurry... so a new old 1920s amp platform will be built, i have all the parts ?part of the knowledge. been studying alot. thank you. will update when i get everything on the platform.
PostPosted: Jul Tue 13, 2021 1:30 pm
You can always replace the cores with new ones from ArbeIII or AES inside the metal shells of the federal, to keep it original looking.
Andrew
PostPosted: Jul Wed 14, 2021 9:36 pm
Hi MRX , im aware of doing that , which would you recommend ?
PostPosted: Jul Wed 14, 2021 10:04 pm
I like the ARBE III (its made in the USA), but the AES version is less expensive. Probably wont make much of a difference since you only have 2 stages of amplification. You could also find some good cores from older transformers.
Andrew
PostPosted: Jul Wed 14, 2021 10:52 pm
OK , weve got Hammond in Canada , im sure i can get something from them..just have to figure out which model?
Mark.
PostPosted: Jul Wed 14, 2021 11:44 pm
Hammond makes these: https://www.hammfg.com/electronics/tran ... sic/118944
Andrew
PostPosted: Sep Sat 11, 2021 9:37 pm
After finding 12 dead solder joints, and figuring out the grid leak, i finally got the detector working it sounds pretty loud with the tube that was in it when i got it, its loose and full of debris. Ive found that even though solder connections seem stable and good, they might not be, thanks Chas, and everyone who helped.
https://youtu.be/x_Px7tgobL8
PostPosted: Sep Sun 12, 2021 4:20 am
Sorry, other than some microphone handling noises the sound is dead on the video...
But, I'm glad it has worked out.
I blather about solder and mechanical joints all the time. Seems it is still true.
Chas
PostPosted: Sep Sun 12, 2021 7:29 am
It was my second video ever, and was using headphones on the detector and tried to record the sound..guess that doesnt work well. now i will start the Reinartz amp next , been studying schematics and the RCA-Marconi radio repair class and a few other books, so things are starting to make more sense.
