It is currently Dec Sat 04, 2021 1:51 am
 Post subject: Cascoded J310 MW band active antenna
PostPosted: Sep Tue 14, 2021 7:35 am
An active antenna for 1380KHz.
Front end is tuned plus there's a 5 pole robust BPF between active antenna and receiver. This is the best solution I could come up with under 20 minutes. It will give an acceptable performance. Not much extra noise if it's mounted high outdoors and some distance from the house with a coax delivering 12V and feeding the radio at the same time.
C2 is for impedance match and C1 is to resonate the 22uH coil on 1380KHz.
 Post subject: Re: Cascoded J310 MW band active antenna
PostPosted: Sep Tue 14, 2021 7:36 am
RA0SMS vs PA0RDT Active Mini Whip - RA0SMS is Very Noisy - Why?
I have been using a PA0RDT active mini whip from Roelof Bakker for about a year now. The PA0RDT antenna has served me well. Clean and able to pull in signals that a 260 foot loop and various long wires cannot.
https://www.sdrplay.com/community/viewtopic.php?t=4128
 Post subject: Re: Cascaded J310 MW band active antenna
PostPosted: Sep Tue 14, 2021 1:46 pm
Is it gonna work? Simple solution.
Users browsing this forum: Dennis H. and 10 guests
